I have movie data that BD has riped, with subtitles inside.
Just that subtitle is saved as an image.It is probably pgs.
So I'd like to export that image with CLI.
Is there a good tool?
Please answer.
I will also post movie information from ffmpeg.
Stream #0:0: Audio: flac, 48000 Hz, stereo, s32 (24 bit) (default)
Stream #0:1: Subtitle: hdmv_pgs_subtitle (default)
Stream #0:2: Subtitle: hdmv_pgs_subtitle
Export to what format?
ffmpeg -i "input" -map 0:1 -c copy "output.sup"
https://trac.ffmpeg.org/wiki/Map -
Thanks for the reply sneaker.
I did not know the sup file format.
A sup file could be output with this command.
As an additional question, can you break this sup into xml and png, for example?
In the end I would like to ocr this image using "google cloudvison".
So I want to extract image files from sup.
Editing PGS subtitles without OCR
By hatbrox in forum EditingReplies: 2Last Post: 14th Feb 2017, 10:31 -
PGS subtitles standards
By Ayer in forum SubtitleReplies: 9Last Post: 2nd Jul 2016, 01:37 -
Syincing PGS subtitles
By Gabes in forum SubtitleReplies: 0Last Post: 3rd Mar 2015, 17:16 -
How do I save edited subtitles in PGS format (.sup) ?
By c627627 in forum EditingReplies: 18Last Post: 16th Nov 2014, 01:36 -
Pgs greek subtitles where?
By fits79 in forum Blu-ray RippingReplies: 2Last Post: 26th Jun 2013, 03:05
