Results 1 to 13 of 13
  1. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hi all,
    I need a little problem here.
    My original file is 480x720 (2 windows, 360 resolution)
    I need "split" file in 360x480 and joint to 360x960 with ffmpeg.
    Look the screenshots.
    ORIGINAL:
    NEEDED
    Sometimes, the first screen isnt the left screen.
    Claudio
  2. This is trivial if using AviSynth. You already know your way around AviSynth, don't you? Why does it have to be using ffmpeg?
  3. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Yes, I use avisynth and its simple for me but my question is for my friend. He will convert 2000 files
    If u know a batch mode with any software for this, its will save the world
    Claudio
  4. Code:
    ffmpeg -y -i "INPUT CLIP" -filter_complex "[0]split[a][b];[a]crop=iw:ih/2:0:0[r];[b]crop=iw:ih/2:iw:ih/2[l];[l][r]hstack" -c:a copy "OUTPUT"
    should do the trick
  5. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    should do the trick
    Get this Selur:
    Claudio
  6. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Sorry my bad. Its fully work, just change output to 1.mp4 and ok.
    Thank u very much @Selur.
    Claudio
  7. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Selur, I have a pendence.
    ffmpeg -y -i "1 vs 100 (USA).mp4" -filter_complex "[0]split[a][b];[a]crop=iw:ih/2:0:0[r];[b]crop=iw:ih/2:iw:ih/2[l];[l][r]hstack" -c:a copy "%~dpn1.mkv"
    Its works but give me ~dpn1.mkv file name. I want the same name input "1 vs 100 (USA)". How to this? In the batch mode its change, correct?
    Claudio
  8. "%~dpn1" is a batch option, it's not available in the command line.
    So either write a proper batch script where you replace both input and output through some batch shortcuts or write the name,...
  9. Originally Posted by Cauptain View Post
    You should pass name as parameter or explicitly name output by copying it - depends on your usage case.
    Additionally you may wish to control codec and compression - currently you not specifying codecs and parameters and default one are used by ffmpeg (re-compression is mandatory in your case).
  10. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Thank u guys. I will try when in my home.
    Im weak with cml, even reading, there are things I dont understand.
    Claudio
  11. Either hard code the filenames:
    ffmpeg -y -i "1 vs 100 (USA).mp4" -filter_complex "[0]split[a][b];[a]crop=iw:ih/2:0:0[r];[b]crop=iw:ih/2:iw:ih/2[l];[l][r]hstack" -c:a copy "1 vs 100 (USA) side by side.mkv"
    Or pass a filename to a batch file:
    ffmpeg -y -i "%~1" -filter_complex "[0]split[a][b];[a]crop=iw:ih/2:0:0[r];[b]crop=iw:ih/2:iw:ih/2[l];[l][r]hstack" -c:a copy "%~dpn1 side by side.mkv"
    The latter in a batch file is suitable for drag and drop.
  12. Member Cornucopia's Avatar
    Also, I would create a top/bottom-->left/right and a separate bottom/top-->left/right (or you could call it a top/bottom-->right/left) script and do a visual (manual) pre-sort into 2 separate input folders, so they each would be operated on only by the appropriate script.
  13. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Its perfect for my friend Jagabo. Very nice. He can create all videos and rename by list using a renamer software.
    Scott, this stage is much more advanced and I think it is very complicated for him.
    I'll write down your suggestion as I need to learn more tips.
    Claudio
