hey guys,
I am currently recording gameplay (2k60) via OBS Studio, custom output, ffmpeg.
If I choose to record the file as avi and with utvideo codec and pcm audio, and put that into vegas pro, it will take forever to build audio peaks because vegas seems to be forced to read the whole AVI file!! to access its audio track and create the peaks.
If I record something with dxtory (also utvideo, pcm, avi), I get a file that vegas pro is able to read the audio track separately -> audio peaks are available in an instant.
If I compare the media info of the two files, everything seems to be exactly the same, only difference is "writing application" (obviously) and interleave duration (dxtory 100ms, obs studio ffmpeg 21ms)
heres the media info output of the obs ffmpeg avi:
After I recorded an OBS Studio ffmpeg avi, I tried (instead of putting it into Vegas Pro) to extract the audio via different demuxers and also ffmpeg (-vn -acodec copy), no method had an instant copy/paste of the audio track.General
Complete name : D:\Andre\Videos\2018-04-28 21-43-42.avi
Format : AVI
File size : 63.4 MiB
Duration : 1 s 109 ms
Overall bit rate : 480 Mb/s
Writing application : Lavf57.84.100
Video
Format : YUV
Codec ID : ULH0
Codec ID/Info : Ut Video Lossless Codec
Codec ID/Hint : Ut Video
Duration : 1 s 83 ms
Bit rate : 490 Mb/s
Width : 2 560 pixels
Height : 1 440 pixels
Display aspect ratio : 16:9
Frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Compression mode : Lossless
Bits/(Pixel*Frame) : 2.213
Stream size : 63.2 MiB (100%)
Audio
Format : PCM
Format settings : Little / Signed
Codec ID : 1
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 208 KiB (0%)
Alignment : Aligned on interleaves
Interleave, duration : 21 ms (1.25 video frame)
what is going on there?
I really need to record via OBS Studio and I need the file to behave like it is written by dxtory.
Is it possible to achieve that even with a .ts or .mp4 file?
I am looking forward to your thoughts on that!
thanks in advance!
I can confirm, the peak building is slow. If you run the file through Dxtory Avimux (and nothing else AFAICT) the peaks load much more quickly. However, Avimux itself takes a lot of time.
The peaks load even more quickly on an OBS file using its standard codecs: x264 or amd/intel/nvidia video, and aac audio in mp4, mov or mpegts. I always stick to the standard codecs. These codecs get much more attention from the developers and are always going to work better than the others.
Batch replacing video file with a different audio track
By Restricted in forum Newbie / General discussionsReplies: 4Last Post: 21st Jun 2017, 07:30 -
Add an AAC audio track to video file
By yardline in forum Video ConversionReplies: 2Last Post: 1st Mar 2017, 05:12 -
replacing (and syncing) an audio track of an MP4 video file
By rotchild in forum Newbie / General discussionsReplies: 6Last Post: 23rd Dec 2016, 05:32 -
replacing (and syncing) an audio track from an MP4 video file
By rotchild in forum RestorationReplies: 0Last Post: 14th Dec 2016, 21:30 -
how to encode ONLY the audio track from a mp4 video file ?
By Michael REMY in forum EditingReplies: 5Last Post: 28th Aug 2015, 23:38
