Can I force ffmpeg to transcode 59.94 frames to display at 25 frames per second by telecine or some other technique? Without dropping frames?
Your request is confusing at best. Do you want to interlace or telecine or both?
telecine is usually used to produce extra frames, while interlace halves framerate.
So if you want to move from 50 FPS progressive to 25 FPS interlaced, use interlace or tinterlace filter.
Look at documentation here: http://ffmpeg.org/ffmpeg-all.html#toc-interlace -
You can use frame rate converter - not so long ago (AFAIR less than 1 year) motion interpolation filter was added - https://ffmpeg.org/ffmpeg-filters.html#minterpolate . You can convert framerate up and after this decimate with constant factor.
Replace random duplicate frames with black frames (AVISYNTH)
By benzio in forum EditingReplies: 7Last Post: 31st Jan 2018, 17:43 -
FFMPEG PNSR Match frames
By themoog in forum Video ConversionReplies: 1Last Post: 13th Nov 2016, 10:29 -
ffmpeg: setting IDR frames option.
By Prathamesh in forum Video ConversionReplies: 10Last Post: 12th Nov 2015, 15:22 -
Combed frames after IVTCing with ffmpeg
By Makaveli84 in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2014, 17:18 -
set FFMPEG so it encode all but without the first 10 frames
By marcorocchini in forum Newbie / General discussionsReplies: 33Last Post: 26th Oct 2013, 21:08
