it doesn't have to be an all in one player. if you think there is a software that's best suited for music, you can separate it from your recommended video player. for example, i use mpc-hc for video playback. for music, i use aimp.
take note i am looking for your opinion regarding which apps have the best video and audio quality playback and not necessarily the best compatibility. a lot of you might mention vlc but i honestly believe its playback quality is quite average. do try to change my mind if you think otherwise.
lastly, do codec packs improve playback in any aspect? if my player has built-in compatibility with my files, do i still need codec packs?
Results 1 to 9 of 9
i was actually hoping that people wouldn't ask that because to be honest, i thought we would already be in the same page after you read my post. i know 'best' is usually subjective which is why i said i was asking for opinions.
by best video quality, i meant picture quality. i really can't explain more than that. maybe what maximizes the settings that were used to encode the video or something? for audio, maybe what sounds good to you, produce less artifacts, has features like an equalizer?
i am sorry if you expect a technical explanation. if you find it hard to understand what i mean, maybe you can just say what you use and say why. -
Yes, it's not easy to say what you mean by "quality", anyway, I tried almost every video and audio player, do you know MV2 Player? It was great, but it's quite "dead", with every video/audio player I tried almost every option and for me, the best audio and video players are:
AIMP for audio.
PotPlayer for video.
I can't imagine to use any other programs, these programs are so good, with so many useful options, PotPlayer is not so easy to configure, but once you done, it's almost perfect.
Friend who had bad HW had problems with VLC and HD, but it was perfect with PotPlayer. I found some bugs and some of them were fixed in few days! One bug in VLC was fixed after 6 YEARS after reporting!! Opening is sooo slow, it's better now, but the first start and video start is still very slow.Last edited by Dreamer; 28th Apr 2018 at 08:33. Reason: typo
For video/movies I use either Kodi DS Player or PotPlayer. I use madVR as the video renderer and it is supported by both players. I prefer the video quality from madVR.
For audio files I use AIMP. Nice, skin-able interface and good options to playback using various audio playback methods.
J
Playing forced subtitles - Windows Media Player/Media Player Classic
By pizzaboyUK in forum SubtitleReplies: 3Last Post: 18th Mar 2015, 02:57 -
Video works in Windows Media Player but not VLC or Quicktime
By david0288 in forum Video ConversionReplies: 2Last Post: 17th Mar 2015, 16:09 -
vlc media player rotates the video, but the quality is getting lost
By jraju in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2014, 11:03 -
audio skips in vlc, but not in windows media player
By steffen707 in forum Video ConversionReplies: 21Last Post: 29th Apr 2014, 13:25 -
Apparently Windows Media Player is oriented for certain video types
By brassplyer in forum Software PlayingReplies: 1Last Post: 23rd Oct 2013, 13:01
