Ok, so I finally bought an AppleTV 4 and I've been blissfuly been ripping my DVDs and Blu-Rays using either Wondershare Video Converter Ultimate (10.1.0) or Leawo Blu-Ray Ripper (7.7).
I loaded them into iTunes Home Videos for AppleTV Playback.
I'm up to 406 movies/shorts.
I've been upscaling to HD 1080P (1920 x 1080).
When I play the files, panning shots have a stilted Jittery/Judder/Stutter feel. It's definitely the files themselves as I've tried playing in both QuickTime Player (10.4) and iTunes (12.7.4.76).
The problem isn't fixed changing the video output settings on the AppleTV and my TV doesn't have special preferences I can adjust to help matters.
The problem happens with both DVDs and Blu-Rays, live action or animation.
Does anyone know a better format/codec that can be played through iTunes/AppleTV that won't have this problem?
I wouldn't be so sure about that. It could easily be the player can't keep up because the passages you describe would have a higher bitrate than the other parts of the films. You could try limiting the max bitrate in your encoding programs.
I suspect that the sample you provide won't be a problem for many here but should be provided nonetheless, in case something else is really responsible. -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
1080p vs 720p Video File on 50" to 60" LED TV
By gonwk in forum Newbie / General discussionsReplies: 13Last Post: 19th Feb 2015, 10:11 -
Downscale 1080p on a 19" vs. upscale 720p on a 22"
By videohalp in forum Newbie / General discussionsReplies: 2Last Post: 12th Jan 2015, 22:20 -
24 fps and "very fast" = STELLAR DVD rips in Handbreak
By rdeffley in forum DVD RippingReplies: 53Last Post: 3rd Jan 2015, 02:44 -
convert three files : ".au" ".temp_audio" " .temp_video" files to mp4
By correx in forum Video ConversionReplies: 4Last Post: 20th Nov 2014, 05:15
