Where can I download portable versions of media players, which cannot be found on this site, such as portable versions of PotPlayer and GOM Player?
What player do you use? I would stick with one.
I personally use MPC-BE for years, even MPC-HC was then developed "actively".
There is a portable 7z/zip available, just extract it and save settings to ini file -> see first options page.
PotPlayer installer exe can be unzipped with 7-Zip, but I don't use it, for several reasons.
GOMPlayer, well, keep away from it. -
Regarding PotPlayer - Polish translator makes portable versions of the program with a few addons (OpenCodec, AviSynth+, VapourSynth & SVPflow, some configured profiles)
https://potplayerclub.pl/download/download-category/pot-pl/
If you browse his website deeper (with help of Google translate) you might find more interesting things. -
Portableapps.com has portable versions of ALOT of programs and have been tested beforehand to run as such. You dont need to install portableapps itself to thumbrive, you can usually just unzip the program you want to a folder and run it unless it has external portable dependencies
if all else fails read the manual
General quality of hardware media players
By newpball in forum Media Center PC / MediaCentersReplies: 6Last Post: 3rd May 2015, 18:37 -
End all be all of stand alone media players or that can be updated?
By LoveDeezNutz in forum Media Center PC / MediaCentersReplies: 13Last Post: 11th Mar 2015, 14:44 -
Dune 303d Media Players
By cornemuse in forum Media Center PC / MediaCentersReplies: 0Last Post: 13th Jun 2014, 13:31 -
which media players do you own and which should I get
By Tedbundy in forum Media Center PC / MediaCentersReplies: 10Last Post: 26th Sep 2013, 16:38 -
3D digital media players
By realrisk2 in forum Software PlayingReplies: 2Last Post: 23rd Sep 2013, 14:53
