  1. Hi. Here in the UK, ITV have been showing a 5 episode series called Last Laugh in Vegas which I've been downloading from the 'ITV Hub' (their equivalent of the BBC iPlayer) using youtube-dl. All 5 episodes are online but, for some reason, I can't download Episode 4. Details are in the attachment. I used copy/paste for the url so it's not as if I've made a typo.
    If anyone can tell me what the problem is and how to get around it, I'd be really grateful. Thank you.
  2. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Is the 5th episode current as in requires login? Here in the US ABC only has certain episodes that are viewable without user credentials.
    if all else fails read the manual
  3. Hi dannyboy - here in the UK, all 5 eps are available but login is necessary for all. Are you saying that Last Laugh in Vegas is on ABC? I had a look at abc.go.com but the search box found nothing.
  4. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    It's not, was just using as a example.
