During VHS capture these units will power down with no interaction after an hour or so of pass-through, halting the signal. I have to then manually find where it turned off and restart the capture from that point. How do I fix this annoying "feature"?
JVC SR-V101US --> DMR-ES10 --> AVT-8710 --> ADVC-55 --> PC WinDV
Thanks,
Brian
try the timer function - http://tv.manualsonline.com/manuals/mfg/panasonic/dmres15_1.html?p=36
That's exactly it.. "Off Timer", thank you!
Off Timer
Select how long the unit remains on when it is not being used.
Is there a Windows 7 driver for Panasonic DMR-ES15?
By digicube in forum DVD & Blu-ray RecordersReplies: 1Last Post: 17th Apr 2017, 20:59 -
Need help my Panasonic won't turn on (DMR-EH60)Already took out power board
By JoseD in forum DVD & Blu-ray RecordersReplies: 4Last Post: 20th Apr 2015, 19:25 -
Panasonic DMR ES15 DVD drive problem stuck on loading cycle
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 8th Jan 2015, 17:40 -
Panasonic DMR ES15
By StrobeLightEpileptic in forum Capturing and VCRReplies: 36Last Post: 31st Aug 2014, 09:54 -
Where to buy Panasonic DMR-ES15 remote?
By Brad in forum DVD & Blu-ray PlayersReplies: 4Last Post: 5th Jun 2013, 21:42
