I can capture to the preset formats, but if I try to capture to an AVI format set up in custom, there is nothing saved. When I click record it says recording to g:\noname although it does'nt say anything about frame drops (ie <1%frame drops) like with the preset formats. And when I look on the G drive there is no file there.
Craig
See if you can just modify an existing preset (change the resolution or whatever) and save that as a custom, then see if it will let you capture.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
I have to set custom avi presets in 7.1 and load 7.6 on top, and they carry over. You can also regedit your customs in 7.1.
If i select custom it does not capture whether they are existing formats or not (even unmodified ones), the only ones it will capture to are the standard formats like DVD, Good and VCD. (The ati VCR formats)
Craig -
Wow, your 'G:' drive? Must be nice. I'd make sure your capture settings are going to a real (valid) drive and directory...and not out to your CD drive or something.
I had the same thing happen. Started using the browse function instead of fat-fingering the directory names to save the capture too.Also happened when the name of the show was invalid for a file name to save the capture to. Now I just use 'Channel Number' nice a safely.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/ -
I have the latest capture drivers from ATI and my G drive is a valid 120GB hard drive, if i use the default filename of noname it still does not capture. I can capture with IUVCR no problem so im not that bothered. Just dont understand why, when it says recording there is no file there.
Craig
ATI MMC 8.8 - capture driver not listed in registry?
By justin81 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 10:13 -
VirtualDub..cant set custom format or compression???
By jranaudo in forum Capturing and VCRReplies: 4Last Post: 16th Jan 2010, 10:54 -
Force custom resolution for TV out in CLONE mode for DV Capture ?
By TheParadoX in forum Capturing and VCRReplies: 4Last Post: 6th Oct 2008, 19:00 -
ATI AIW X800GT - ANY capture software besides MMC?
By nbarzgar in forum Capturing and VCRReplies: 23Last Post: 18th Nov 2007, 01:24 -
Anyone using MMC with X800XL VIVO-only (no TV tuner or AIW) for capture?
By palouse in forum Capturing and VCRReplies: 4Last Post: 15th Aug 2007, 02:28
