Hello, all:
I am using MKVToolNix 22.0 in Win 7 64-bit.
There is a problem when MKVToolNix make .mkv file.
For example, I have a xxx.h264 file, it is 1000 bytes. I use MKVToolNix to generate the xxx.mkv.
And then extract the video track from xxx.mkv as xxx_track1.h264. It become 1038 bytes.
Do it again, I use MKVToolNix to generate the xxx_track1.mkv
and then extract the video from xxx_track1.mkv as xxx_track1_track1.h264. Now, it become 1076 bytes.
Every time when using MKVToolNix to generate mkv file, the MKVToolNix will add 38 bytes in video track.
This is very strange. Does anyone has same problem like me or any idea ?
Thanks in advance.
Maybe look at the two .h264 files in a hex editor (like Hexplorer or HxD) to see what has changed. It's probably just added header information. If the video plays back the same then I'm not sure why you started this thread. It's certainly not encoding the video again.
Yes, most likely. When muxing mkvmerge reads header information (SPS/PPS) from stream and writes into Matroska "CodecPrivate" element but doesn't delete them from the bitstream data. On demuxing mkvextract writes the CodecPrivate content in front of the stream again. So each time you mux->demux the SPS/PPS is duplicated. It is not a problem per se but can be avoided by some demuxers if you absolutely want to (e.g. eac3to).
Problem remuxing blu-ray rip using MKVtoolnix
By Odaik in forum Blu-ray RippingReplies: 25Last Post: 10th Jul 2016, 01:54 -
MKVToolNix GUI muxing - problem with chapter
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 3Last Post: 27th Jun 2016, 22:18 -
Problem after Install- MKVToolNix
By Ralph11 in forum Newbie / General discussionsReplies: 1Last Post: 14th Sep 2014, 12:31 -
mkvtoolnix problem
By aLTERLENIN in forum Video ConversionReplies: 9Last Post: 6th Jun 2014, 05:04 -
MKVToolnix remuxing problem?
By PonyoBellanote in forum Video ConversionReplies: 10Last Post: 5th Oct 2013, 05:55
