Hi,
Quick question folks.
I'm backing up one of my NTSC DVDs (29fps) to x264 using AVIsynth and XmediaRecode. I'm not sure of any other tools which will allow me to import an AVS file. I created a d2v file with demuxed audio using DGindex. I'm using the Tdecminate and TFM to revert the footage back to 24p.
The demuxed audio AC3 filename states DELAY -33. My intention is to import the AVS file and AC3 audio into Xmediarecode to convert to x264. I will be maintaining the original audio format therefore do not intend to convert it, just copy it across. The problem is that under the audio tab there is no field to set the audio delay.
I did try going ahead with the encode without setting an audio delay. During playback the audio seems fine although the delay of -33 seems very minimal. It's hard to tell as it's an anime DVD that I am encoding.
How will the audio be impacted in this scenario?
Should I just encode the video only and then use a muxing tool which gives the option to set an audio delay?
Are there any other encoders like XmediaRecode that support AVISYNTH files?
Instead of doing a negative delay on audio you can also just delay the video by e.g. duplicating the very first frame in AviSynth:
DuplicateFrame(0)
At 24 fps 1 frame is shown 41,7ms so difference then is only 8,7ms. Often with AC3 we have 5ms encoder delay. So then really only 3,7ms delay remain which is good enough. (Even 33ms is often good enough. Source probably isn't that exact anyways.) -
Forget for a moment that I am reverting to 24p. For arguments sake if I left the framerate untouched and imported my avs and ac3 files into XmediaRecode, would the software know to apply an audio delay of -33 from referring to the filename?
Mediainfo-ing the source vob file states there is an audio delay of -33.Last edited by Imy; 22nd Apr 2018 at 16:32.
Probably not but I haven't tested. If anything it would just read from the file name. You could easily test by changing the filename to e.g. "whatever DELAY -5000.ac3" and then look whether or not the audio is 5 seconds off.
Assuming you used DVDDecrypter to decrypt the DVD to the hard drive, you can ignore that -33ms delay. It's a known bug in DVDDecrypter. The delay is really 0ms.
Where am i wasting cpu for least impact in quality
By ben45 in forum Video ConversionReplies: 8Last Post: 15th Aug 2016, 18:46 -
question about audio/ video sync
By shokan22 in forum Newbie / General discussionsReplies: 15Last Post: 8th Apr 2016, 15:31 -
Latency in relation with and its impact on bandwidth
By vhfu in forum Video Streaming DownloadingReplies: 3Last Post: 12th Mar 2014, 14:19 -
Re:- sync Audio to Vedio - audio starts in sync but goes out of sync at end
By ABBrittain in forum Newbie / General discussionsReplies: 2Last Post: 22nd May 2013, 12:08 -
audio sync problem - progressively out of sync during playback - MPEG 2
By TheShortStraw in forum Newbie / General discussionsReplies: 4Last Post: 20th May 2013, 07:36
