Hello, I have exactly the same issue. First I had a problem with the wave being too zoomed in but that was fixed thanks to this forum but now the volume issues. Like some of the previous posters I couldn't find the folder. I found a contents folder but I don't know what to do after that.
Can anyone help? Thank you.
Edit: I'm using Mac.
Results 31 to 37 of 37
Hi, I just managed to find the folder some people mentioned(for Mac). Just looking at it you may not find it but you all should have it.
In my case: Macintosh HD -> Library -> Application Support -> Aegisub -> config.json (as schmick wrote– thanks!)
Open it with textedit and change as Maikol suggested. Save it and it should work.
"Volume" : 50,
"Wheel Default to Zoom" : false,
"Zoom" : {
"Horizontal" : 0,
"Vertical" : 50
You just have tu set Volume to 50 and Vertical to 50 too.
OR press option key and click "Go" on top of your screen. You see "Library" then go to Application Support and find Aegisub folder. Good luck!Last edited by spencer; 9th Oct 2019 at 19:33. Reason: additional info
Thread moved to the mac forum.
Guys I found the solution.
You need to delete associated aegisub files/folder manually:
Open the Finder, go to the Menu Bar, open the “Go” menu, select the entry
Go to Folder... and then enter the path of the Application Support folder:~/Library
/Library/Preferences/
/Library/Application Support/
/Library/Caches/
Reinstall Aegisub, done
More Info : https://www.uninstallmacapp.com/aegisub-3-2-1-removal.html -
Guys, thanks for all the help here.
I opened the config file and changed the zoom part to zero and that worked.
But I have another issue and I need some help solving it: the red and blue bars from the spectrum are not changing the times from the selected part of the video/audio.
That means that when I move the red or blue bar, the time selected (which is shown below the spectrum) does not change. Therefore, the spectrum becomes useless and very difficult to work with.
Has anyone had that problem as well? Can anyone help me on that?
Btw im using MacBP 2012 on Mojave.
Thanks! -
I literally just registered for this site to say thank you!! and to update anyone who is trying this with a newer OS....I just downloaded this software today not mega computer savvy (especially with Macs I hate this thing, can't wait to get a new windows computer) but I was able to adjust the coding and fix the issue! i was having a problem with it zoomed in and also the audio suddenly sucked. it's now back to normal. I found the file under:
macintosh HD > users > (my login name) > library > application support > Aegisub > config.json
yay!!
now i can continue making my karaoke video
need for a spectrum analysis
By rama in forum AudioReplies: 8Last Post: 6th Jul 2020, 08:59 -
VSDC software: Zoomed text
By Engadin in forum Newbie / General discussionsReplies: 0Last Post: 27th Jan 2017, 12:15 -
Sharp LC32DA5U - Stretched/Zoomed view on TV and HDMI
By Human in forum Newbie / General discussionsReplies: 2Last Post: 17th Nov 2016, 19:31 -
Making Zoomed videos Clearer
By tyler1200 in forum EditingReplies: 3Last Post: 20th Aug 2016, 21:04 -
Does Vegas lose quality when zoomed panned
By Anonymous in forum Newbie / General discussionsReplies: 4Last Post: 29th Feb 2016, 06:49
