Usually, most of the satellite channels gives a ts with M=3 N=12 GOP. I take the recorded file and feed it to ProjectX and demux it in order to fix the a/v sync then remux it and trim. There is a weird channel which gives a transport stream of variable GOP. Here's part of the continuously repeated error which ProjectX shows
The output is a well synchronized video however with a shorter duration due to the dropping of GOPs.Code:!> dropping GOP# 208 @ orig.PTS 00:03:14.240 (17481600), errorcode: 24 !> Pics exp/cnt 25/39, inGOP PTS diff. 0ms, new Timecode 00:02:11.560 !> dropping GOP# 209 @ orig.PTS 00:03:15.240 (17571600), errorcode: 24 !> Pics exp/cnt 24/34, inGOP PTS diff. 0ms, new Timecode 00:02:11.560 !> PTS difference of 176400 (00:00:01.960) to last exported GOP detected !> dropping useless B-Frames @ GOP# 210 / new Timecode 00:02:11.560 !> dropping GOP# 218 @ orig.PTS 00:03:23.920 (18352800), errorcode: 24 !> Pics exp/cnt 24/41, inGOP PTS diff. 0ms, new Timecode 00:02:19.160 !> dropping GOP# 219 @ orig.PTS 00:03:24.880 (18439200), errorcode: 24 !> Pics exp/cnt 23/33, inGOP PTS diff. 0ms, new Timecode 00:02:19.160 !> PTS difference of 169200 (00:00:01.880) to last exported GOP detected !> dropping useless B-Frames @ GOP# 220 / new Timecode 00:02:19.160 !> dropping GOP# 225 @ orig.PTS 00:03:30.600 (18954000), errorcode: 24 !> Pics exp/cnt 25/32, inGOP PTS diff. 0ms, new Timecode 00:02:23.840
How do i fix the audio/video sync for this specific channel (with/without ProjectX)?
Results 1 to 1 of 1
Encoding HDTV anime transport streams; need it to not look bad
By cloaknsmoke in forum Video ConversionReplies: 5Last Post: 21st Aug 2016, 14:08 -
How to deal with 2.0 AC3 inside 5.1 streams properly
By bilditup1 in forum DVB / IPTVReplies: 0Last Post: 20th May 2016, 15:25 -
Demux DVB-S2 HD transport stream
By geohei in forum EditingReplies: 1Last Post: 16th Dec 2014, 11:20 -
Getting top quality Kbps from streams using variable bitrate screen control
By jilly in forum Video Streaming DownloadingReplies: 7Last Post: 1st May 2014, 15:42 -
How to? Join Mpeg-2 Transport Streams?
By TheCheatG5 in forum MacReplies: 7Last Post: 6th Feb 2014, 03:44
