Hi
I'm trying to convert a DVD to VCD or SVCD using Pinoys guide. I've downloaded all the software except SSRC which I cannot seem to find (link broken) is there another source for this file?
When using VOB to audio after the DOS box I get the error message 'Ligos splitter seems to miss an audio stream use the audio vob option in smart ripper or use vob tools to delete first segment'.
I apologise if these are old questions but I could not find anything in the FAQ etc.
Thanks in advance
Jon
Personally I did not have much luck with vob2audio, so my first suggestion is to use BeSweet instead.
Anyway, you may try this Ligos splitter patcher
http://mujweb.cz/www/a0zatvrd/Ligos%20Patcher.exe
and maybe update streams.
http://mujweb.cz/www/a0zatvrd/Streams_2_6_9.exe
and here is sscr1.29
http://www.doom9.org/Soft21/Audio/ssrc-1.29.zip -
Hell I posted a bunch of dead links only. I will keep on searching.
edit: I gave up. Download the 3 in 1 package here if you like.
http://mitglied.lycos.de/vcdhelp/utils.rar -
Many Thanks!
I found SSRC and I've done a succesful back-up from another DVD. Vob audio seemed to work with this DVD. Spliiting the MPEG for 2 VCD's seemed to change if from the MPEG format although when played with the media player it worked.
On burning Nero gave the error message so I chose 'turn off standard compliance' and burnt and it plays fine in my VCD.
Is there another program for splitting the large MPEG which is better than the tool in TMGEnc?
Thanks again - Clearly I have a lot to learn.
Cheers
John
error message coverting vob to wmv
By DaveE in forum Video ConversionReplies: 1Last Post: 1st Mar 2010, 06:50 -
Avisynth "ssrc resample audio" help
By DaneClark in forum Video ConversionReplies: 0Last Post: 10th Jul 2009, 23:50 -
VirtualDub Error Message - Video Compression Error
By HartsVideo in forum DVD RippingReplies: 19Last Post: 7th Jun 2009, 20:18 -
unsupported audio type error message in AutoGK
By ham2405 in forum AudioReplies: 2Last Post: 26th Dec 2007, 16:53 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
