I am trying to capture analog Hi8 video from a Sony TRV-328. I have bought a VideoGrabber that plugs to the USB, and only get the video but no sound. Am I doing something wrong? How can I fix this? My computer is running Win10.
Did you connect the black plug from the Sony A/V cable to the white or red jack on the Video Grabber?
Also make sure your capture software is set to record audio from the capture device, not the the computer's microphone, line-in, or other audio source.
- My sister Ann's brother
Thanks to each of you.
I tried the black plug in each the red and white.
As far as setting the capture device to record audio, there does not seem to be an option. It shows only line in.
Sorry to be so dumb about this.
As for Windows 10 that is what I have!!! -
Make sure the Sony AV cable is pushed all the way in. Try some DeOxit on the jack. Plug the black RCA connector into a stereo or something else that has an RCA audio input. If no sound, then the cable is bad, the camera is bad, or there is no audio on the tape.
Dare I ask the make/model of this video grabber ?
If there is no setting in the capture software for audio connected direct to the grabber you will have to connect the audio cable to your audio-in connector on your sound card or main board. And then you might have audio sync issues.
Digital to analog TV converter question
By Aldbaran in forum DVB / IPTVReplies: 2Last Post: 30th Sep 2017, 17:34 -
Digital8 camcorder not playing analog recordings well.
By digicube in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 11th Jan 2017, 19:10 -
analog-to-digital passthrough
By giancarlo in forum Capturing and VCRReplies: 3Last Post: 13th Mar 2016, 14:26 -
using a camcorder as a pass through to digitize analog tapes
By davidtall in forum Newbie / General discussionsReplies: 2Last Post: 3rd Mar 2014, 15:31 -
digital 2 analog audio
By downriver in forum Newbie / General discussionsReplies: 12Last Post: 28th Apr 2013, 11:58
