Hi there,
I have several downloaded Divx files which are excellent quality movies. When I try to convert to either MPEG 1 or 2 the finished article isn't as good as the original. I have followed the instructions on here, even converting at highest quality in TMPENG but still no good. The finished file plays but its almost like theres a brief pause as the start of each frame, as if its struggling, probably not the best way to describe but hopefully somone can help ?!?!?!?!?
Thanks,
Angel
Hi Angel,
Well, i'll begin with this, no matter what your source is, you will never get the same quality when you encode it.
That out of the way, will get down to business, AVI/DivX is a highly encoded source, meaning an encoder has a hard time figuring out how to compress it proparly while maintaining good quality.
DivX may look great sometimes, but that's because the human eye cannot catch alot of defects, while the encoder has to work with the data itself that the DivX delivers, and there isn't enough for it to work with.
Now regarding your problem, it sounds more like you simply used an incorrect settings on your encode which does not match your source file, and that causes the brief pauses every now and then.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician.
Conversion Problem
By Myrdivar in forum Video ConversionReplies: 3Last Post: 2nd Jun 2011, 04:44 -
Problem with conversion to DV
By SteveDM in forum ffmpegX general discussionReplies: 3Last Post: 25th Aug 2010, 08:54 -
conversion problem
By thomeski in forum Authoring (DVD)Replies: 2Last Post: 25th Apr 2010, 20:45 -
Help conversion problem!
By milney100 in forum Video ConversionReplies: 6Last Post: 11th Jun 2008, 05:51 -
video conversion problem
By eagle1 in forum Newbie / General discussionsReplies: 5Last Post: 2nd Jun 2008, 21:25
