Page 2 of 2
FirstFirst 1 2
Results 31 to 55 of 55
  1. All Japanese marketing material and commercials never mean what it shows and are crazy as f***
    https://www.youtube.com/watch?v=VQ3I23b1OyI
    Ever see a Japanese newspaper or magazine? Even the print ads are odd.
  3. Originally Posted by lordsmurf View Post
    Tell me about it! Lived there for over 12 years.
  4. It has been confirmed that IO DATA USB2 can support PAL. But there is no other model support. I recently bought a CANOPUS DXV E-1 looking for win7 64 driver Has anyone given me installation instructions
  5. Looking over the internet, there's no win7 drivers and on the glassvaley forums they say there will never be one.
    What I use to capture NTSC and PAL is the Canopus ADVC-100.
    This was a capture from a VHS source with ADVC-100 and latter stored in a MiniDV tape.
    https://www.youtube.com/watch?v=lq42bnlm6OQ
    The good about it, aside the great quality capture capability, is that it doesn't choke or stop capture with bad VHS tapes. The captures keep going pretty stable.
    This one is the worst tape I ever captured, the original was PAL-M, then converted to NTSC, the person did a dozen copies of the 5th generation tape and one of this copy landed on my hands.
    https://m.youtube.com/watch?t=1s&v=3sjHq_e-ZeA
    The tape had a lot of glitches, the second half of it (around 52 min) was very unstable, recorded on EP or lower speed, the screen was shaking at the top but as you can see, the capture is rock solid. There is a time when the the tape is havy damaged but the capture continues still.
    Try to find a ADVC-100 first generation models, don't know about the ADVC-110 and latter.
  6. Originally Posted by amaipaipai View Post
    https://www.youtube.com/watch?v=gQZob5zjewk I prefer this effect. I'm sure it is the effect of the NEC chip because IODATA is also such a chip. I have bought a CANOPUS DXV E-1 but she is not WIN7
  7. If you really want to use this outdated hardware, all you have to do is to consider getting an old computer, install Windows XP on it to capture whatever you need. Or backup your stuff and try to do a dual-boot between your current OS and XP.
    You can also try your luck with Linux, it might have the necessary drivers to make this work again with a modern computer.
  8. Originally Posted by amaipaipai View Post
    I discussed it with a capture person in mainland China. First of all, the capture S terminal generally supports only (720SD), and only individual devices can support 1080. This is a problem with the chip. Can be considered is decklink and canopus AJA (this is good for MAC support) but DECKLINK seems to need to convert AV. Causes color problems.
  9. Originally Posted by amaipaipai View Post
    IO DATA Is there a PAL PCI capture card? You lived in Japan and told me next.
  10. Sorry, it's hard to understand you.
    Back in my days in Japan, I never liked IO Data brand or products because a bad experience with a Magneto Optical DRIVE, I rather prefer Buffalo's.
    Why you are so fanatic about IO DATA?
    Do you know Blackmagic Intensity Pro?
    It has all the inputs you need to capture your stuff, it has a model for USB 3 or Thunderbolt (Mac), it works with Windows 7 and does capture PAL. If your PC doesn't have a USB 3 port, you can buy a USB 3 PCI board.
  11. Originally Posted by amaipaipai View Post
    OK, now I deleted my point of view
    IODATA claims that their product PCI has a certain amount of memory as a row TBC, a ghost reducer, and DNR technology.
    IODATA with NEC chip exceeds LSI or DVD burner level of Panasonic chip
    Can you recommend NEC chip S-vidoe native capturecard? Support WIN7 64 is best to support potplayer
  12. Image
    [Attachment 45533 - Click to enlarge]
    NEC series chip Japanese manufacturers: IODATA canopus and Buffalo's.
    Ghost Retarder+Line TBC+DNR=JVC TBC(i think)720 NTSC.
  13. Visual key calculus statistics:
    720SD: If S-VHS+NEC IC can exceed DVD quality, see youtube proof.
    With LSI chips it is difficult to exceed DVD quality.
  14. Image
    [Attachment 45535 - Click to enlarge]
    China avermedia = garbage chip
  15. Originally Posted by amaipaipai View Post
    I bought many VHS digital discs from large commercial publishers in Japan on DMM. If they look at the color vision, they should be IODATA devices.
  16. OK, now I deleted my point of view
  17. OK, now I deleted my point of view
  18. Sorry, still can't understand you.
    ADVC-100 uses NEC UPD72893AGD and Philips SAA7114 and captures NTSC (720x480) and PAL (720x576).
    All this are captures samples from ADVC-100 using S-Video
    If you need a TBC:
    https://www.bhphotovideo.com/c/product/276891-REG/AV_Toolbox_AVT_8710_AVT_8710_Multi_S...Time_Base.html
    Some say that Hauppauge has a internal TBC
    https://forum.videohelp.com/threads/329139-Hauppauge-Colossus-HD-PVR/page5
    This helps?
    http://tanlon.net/Item/210.aspx
    Other than that, sorry, I can't help you.
    Image Attached Thumbnails UPD72893AGDLML.pdf
    SAA7114.pdf
  19. Originally Posted by amaipaipai View Post
    If you need a TBC:
    This helps?
    メイン基板裏側
    BW800以上にシンプルな基板、これであれだけの機能を実現できているところがすごい
    UniPhierとメインメモリ以外の実装デバイス
    ネットワーク用にカニさんチップ "RTL8140L"
    USBポート用にNECのUSBコントローラ "μPD720102"
    1Gbit SLC NANDフラッシュメモリhynixの "HY27UF081G2A"
    TIのIEEE 1394a 2ポートトランシーバ "TSB41AB2"
    24Bit 96kHzオーディオ用ADCにAKMの "AK5367"
    AKMの2Vrms出力の24ビットDAC "AK4420"
    電源制御LSI "THV5804"、"MB39A128A"
    電源用オペアンプ JRC "NJM2904"
    松下8ビットマイコン "MN101C77"
    MACアドレスとかが入ってるっぽいSIIのSerial EEPROM "S93C46B"
    Silicon LaboratoriesのEmbedded Modem IC "Si2404-FS08"
    用途不明な松下の"AN13351"
    その他
    http://pocketnews.cocolog-nifty.com/pkns/2008/08/bddiga_dmrbw830_6a20.html
  20. 日本語で書かてもちょと分かりにくいだけど。
    申し訳ございませんが助けることができないですよねぇ。
  21. Originally Posted by amaipaipai View Post
    ADVC-100使用NEC UPD72893AGD和Philips SAA7114,捕捉NTSC(720x480)和PAL(720x576)。
    Friends, what you said was like ADVC's front interface box. I refer to the analysis of canopus editing card. It seems that you should look at the main card design. Usually Japan's top capture card consists of an interface switch and a master card. Thank you
