This 12GB file is great quality, and has subs. But there's a Mel Gibson commentary track I'd like to lose.
Can I do this with Subtitle Workshop?
Post the media info of the track...
If the MKV, use MKVToolkit to remux the file and uncheck the commentary track.
Subtitle Workshop can only work with TEXT based subtitle tracks -
OK, thanks. So MKVToolkit just copies the entire original but leaves out any deselected sound track?
Yes!
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
teodz1984 and netmask56: Much thanks. I'm a newbie at this
I thought I'd uploaded an attached Media Info file, but I'll incude it in the post, just in case.
Cheers.
General
Unique ID : 203640399036811696940817301870849553760 (0x9933B6D86144E2EAAED5B97FF76FF560)
Complete name : M:\KEEPERS\Apocalypto 12GB-S.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 11.6 GiB
Duration : 2 h 18 min
Overall bit rate : 12.0 Mb/s
Encoded date : UTC 2016-04-29 15:54:08 / UTC 2016-04-28T02:24:21Z
Writing application : mkvmerge v8.3.0 ('Over the Horizon') 64bit
Writing library : libebml v1.3.1 + libmatroska v1.4.2 / Lavf55.12.0
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Bit rate : 11.5 Mb/s
Width : 1 920 pixels
Height : 1 040 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.240
Stream size : 10.6 GiB (91%)
Writing library : x264 core 142 r2479 dd79a61
Encoding settings : cabac=1 / ref=3 / deblock=1:-2:-2 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.25 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=6,6 / fast_pskip=1 / chroma_qp_offset=-4 / threads=12 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=11500 / ratetol=1.0 / qcomp=0.80 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=62500 / vbv_bufsize=78125 / nal_hrd=none / filler=0 / ip_ratio=1.10 / aq=1:0.50
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Statistics Tags Issue : mkvmerge v8.3.0 ('Over the Horizon') 64bit 2016-04-29 15:54:08 / mkvmerge v8.3.0 ('Over the Horizon') 64bit 2016-04-29 15:54:08 / UTC 2016-04-28T02:24:21Z
FromStats_BitRate : 11172693
FromStats_Duration : 02:18:21.312000000
FromStats_FrameCount : 199032
FromStats_StreamSize : 11593501522
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 633 MiB (5%)
Title : Surround
Service kind : Complete Main
Default : No
Forced : No
FromStats_BitRate : 640000
FromStats_Duration : 02:18:21.344000000
FromStats_FrameCount : 259417
FromStats_StreamSize : 664107520
Audio #2
Format : AC-3
Codec ID : A_AC3
Bit rate : 192 kb/s
Channel(s) : 2 channels
Bit depth : 16 bits
Stream size : 190 MiB (2%)
Title : Commentary with Mel Gibson and writer/co-producer Farhad Safinia
Language : English
Default : No
Forced : No
FromStats_BitRate : 192000
FromStats_StreamSize : 199232256
Text #1
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
FromStats_BitRate : 1964
FromStats_Duration : 02:08:40.755000000
FromStats_FrameCount : 1002
FromStats_StreamSize : 1895857
Text #2
Format : PGS
Muxing mode : zlib
Language : English
Default : No
Forced : No
FromStats_BitRate : 2622
FromStats_FrameCount : 1342
FromStats_StreamSize : 2531258
Text #3
Format : PGS
Muxing mode : zlib
Language : French
Default : No
Forced : No
FromStats_BitRate : 1933
FromStats_FrameCount : 1000
FromStats_StreamSize : 1865941
Text #4
Format : PGS
Muxing mode : zlib
Language : Spanish
Default : No
Forced : No
FromStats_BitRate : 1883
FromStats_Duration : 02:17:23.110000000
FromStats_FrameCount : 1004
FromStats_StreamSize : 1940839
Text #5
Format : PGS
Muxing mode : zlib
Language : English
Default : No
Forced : No
FromStats_BitRate : 12085
FromStats_Duration : 02:17:45.882000000
FromStats_FrameCount : 3794
FromStats_StreamSize : 12487654
Menu
00:00:00.000 : :Chapter 1
00:08:19.434 : :Chapter 2
00:13:03.843 : :Chapter 3
00:19:17.383 : :Chapter 4
00:23:09.823 : :Chapter 5
00:32:34.346 : :Chapter 6
00:37:45.281 : :Chapter 7
00:48:28.758 : :Chapter 8
00:56:39.206 : :Chapter 9
01:00:53.877 : :Chapter 10
01:09:15.211 : :Chapter 11
01:18:13.040 : :Chapter 12
01:23:15.884 : :Chapter 13
01:32:12.379 : :Chapter 14
01:43:07.825 : :Chapter 15
01:50:15.085 : :Chapter 16
01:57:45.785 : :Chapter 17
02:08:06.572 : :Chapter 18
02:09:49.133 : :Chapter 19
Just untick Audio #2 and save (start multiplex)
Suggestions for some voice changing software for cartoon voice-overs?
By dilophosaurus65 in forum AudioReplies: 0Last Post: 15th Mar 2017, 16:03 -
NESN rmtp dump?
By islandfever in forum Video Streaming DownloadingReplies: 0Last Post: 13th Aug 2016, 17:42 -
Apocalypto BDRip - Set correct audio language code?
By NuŠleus in forum Blu-ray RippingReplies: 1Last Post: 9th Apr 2015, 16:34 -
Trying to download TV3.ie clip using RTMP Dump
By Anonymous53584 in forum Video Streaming DownloadingReplies: 12Last Post: 13th May 2014, 09:36 -
BSoD Memory Dump whenever rendering Videos
By shadowfigure in forum Newbie / General discussionsReplies: 4Last Post: 29th Apr 2013, 12:55
