I have an LG region free blu ray player that I bought a year ago. I ordered a few PAL region blu ray box sets from amazon.uk and both sets played fine, multiple times. then suddenly, one set of disks won't play. I tried all the disks in the set, and none of them will play. I get the message wrong region or some such. but the other set of disks I bought still play fine. I tried switching back and forth between regions on the player and this one set will not play no matter what even though they played before just fine. really strange. any ideas?
thanks
have you recently updated the firmware on the player ?? does the player have an NTSC / PAL option
does the firmware update automatically? it has a button on the remote where I can switch back and forth from Pal to NTSC. I tried the disks on both and on both I get the message "wrong region". but the other set of disks play fine when I set it to PAL and these disks used to play fine until recently. But it had been a long time, months, between the time I last played them successfully and now.
Check the firmware version - it will/should be listed buried somewhere in the setup or systems menu's. It may have had a firmware update that's killed the region free status.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
found out there isn't even a cable connection for internet on it even though the instructions say make sure your player is connected to the internet, then download new firmware from there. anyway, I tried the disks again, and it just comes up, "wrong region, switch to region B" but it still wouldn't work.
I did a factory reset from the settings, but that didn't work.
then I unplugged the player for a while, plugged it back in, then tried the set of disks that did play ok, and they worked fine as usual, then put in the disks that wouldn't play, and they played! no problem. I don't get it but whatever now they play. thanks for the advice at any rate. I don't know how many times I have some problem with anything, and internet searches can't find any help. then I look on forum's and instant help from people.
Region Free Blu Ray Player
By Alayne Jones in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Jun 2016, 02:38 -
Is there a Blu-Ray Burner / Player I can purchase now that is Region Free?
By andy jackson in forum Newbie / General discussionsReplies: 12Last Post: 17th Feb 2016, 08:43 -
Region Free Blu-Ray Player in Australia?
By magnu in forum DVD & Blu-ray PlayersReplies: 34Last Post: 12th Oct 2015, 19:22 -
Samsung Blu-ray player that is able to be region free hacked?
By moviegeek71 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 1st Dec 2014, 19:10 -
LG BP240 Blu-Ray player region free ?
By Robinaud in forum DVD & Blu-ray PlayersReplies: 1Last Post: 5th Jul 2014, 16:56
