  1. I have a few blu-ray movies that I would like to rip and upload to my plex server. I was planning on getting an external blu-ray ripper but I do not know which one I should get. Is there a blu-ray ripper someone can recommend me to purhcase? Also, which software or decypter should I use? I am not going to be doing any encode but instead just copying the blu-ray movies. I was thinking of getting the "Buffalo - 12x External USB 3.0 Blu-ray Disc Double-Layer DVD±RW/CD-RW Drive" from BestBuy is it a good blu-ray ripper? Heres a link to the item
    https://www.bestbuy.com/site/buffalo-12x-external-usb-3-0-blu-ray-disc-double-layer-dv...?skuId=1374214
    Feb 2006
    try using dvdfab
  3. I'm a Super Moderator johns0's Avatar
    canada
    Makemkv,it's free for now,i like it better than dvdfab.
  4. But what is a good blu-ray ripper? I do not know which one to buy
  5. Mr. Computer Geek dannyboy48888's Avatar
    May 2007
    Texas, USA
    Been using mamkemkv since 2009, loved it so much I bought a license as ita the only good option thats cross platform. It is still free right now though just gotta re register every month. There are a few trouble discs (mainly loinsgate titles) but the forums are awesome and the creator is very active. Far as drives I'm rather fond of my pioneer drives in a USB cradle and the standalone models. Had a buffalo, the bluray part died in 6 months.
    https://www.amazon.com/gp/aw/d/B00GD792US/ref=dp_ob_neva_mobile
    https://www.amazon.com/gp/aw/d/B00OD39P6A/ref=dp_ob_neva_mobile
    As always there us no one good drive these are just what has worked for me
    if all else fails read the manual
    Aug 2006
    Maybe you are asking about which Blu-ray drive to use for ripping your Blu-ray movies rather than what ripping software to use? If so, internal SATA-connected drives are more reliable than USB-connected external drives.
    Ripping Blu-ray discs takes time regardless of which drive is used. I timed it, and it took about 26 min to decrypt and copy a 31GB Blu-ray movie to my HDD.
  7. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    My internal DVD/Blu-ray is one of these http://www.liteonodd.com/en/bd-internal/item/bdinternal/ihbs212 a bit old now but does the job. I transfer all my discs to my NAS and I don't attempt to compress, plenty of storage. I use MakeMKV and that's it apart from DVDFAb Passkey
