So i have been given a cheap telecine box so i've decided to capture my old super 8mm home movies to HD video camera (Panasonic HC-VXF990).
My problem is flicker/thick horizontal black band moving vertically. I know its basically a frame rate issue so i was wondering what the best frame rate would be to record in? 24p 25p 30p? Also would altering the shutter help with this at all?
Also my projector has a speed adjustment dial that helps to slow the thick horizontal black band that moves vertically, but never really gets rid of it all together, it just eventually makes it change direction.
Any suggestions would be greatly appreciated.
Thanks.
You will first need to manually reduce the shutter speed of your Panasonic video camera to 1/50 or 1/25 until the "black line" of the projected image goes away (probably 1/25). Then dial the projector's variable speed knob to fine-tune for a completely flicker free image.
Thank you for the advice, I will give this a go later today and see what happens.
Well that pretty much worked perfect, just a slight flicker remained once I changed the shutter to 1/50 (Camera wouldn't allow me to go lower) So thanks for that. Will fix the rest in post
considering options for converting 8mm & hi 8mm to digital
By glen_s in forum Newbie / General discussionsReplies: 57Last Post: 21st Feb 2024, 16:52 -
Having Trouble with DIY Telecine (8mm) System
By RTLdan in forum Capturing and VCRReplies: 347Last Post: 18th Jul 2016, 02:05 -
Help to buy new Movie Converter super8 / 8mm film telecine machine
By KIG in forum Video ConversionReplies: 0Last Post: 18th Apr 2016, 13:29 -
Home made telecine box
By Nathaniel Lomax in forum TestReplies: 1Last Post: 23rd May 2015, 03:22 -
Trouble With Telecine Box, Image too small
By Nathaniel Lomax in forum Video ConversionReplies: 1Last Post: 8th May 2015, 16:44
