I've encoded a 1080i x264 video to a 720p avi using the Lagarith lossless codec. However it seems as though it uses the same bitrate for 720p as it does for 1080i. Is there any way to get it to use a lower bitrate for 720p?
Or are there any other lossless codecs you can suggest that will give a lower bitrate for 720P?
Typically temporal compression lossless codecs will give better compression ratio e.g. ffv1, x264 in lossless mode with long gop . Lagarith is intraframe only (each frame is individually encoded, instead of using information from other frames and making predictions to reduce filesize)
The "negatives" include reduced compatibility in some applications, slower encoding and significantly slower decoding speed . So depending on the usage scenario you might not want to use them
Do you really need a "lossless" codec ? -
Lossless or Uncompressed - I'll use whatever gives the lowest file size. You mentioned a long gop. I usually use 250. What gop setting should I use?
The reason I want to encode to uncompressed/lossless is that my scripts are very slow so I'll encode to uncompressed/lossless 1 time. Then I can encode that uncompressed/lossless video to a watchable x264 video without a script at a really fast speed since I'm not using a slow script that time. The point is that if I ever want to encode the video again in the future to a future format for example then I can just encode the lossless video really quickly.
What indexers support uncompressed/lossless videos? Need something that will work with MeGUI One-click for batch processing.Last edited by VideoFanatic; 17th Apr 2018 at 19:23.
720p60 is about the same amount of information as 1080i30. That's why they were chosen for broadcast.
Lossless compression
You can leave the GOP settings at default 250 . There are negligible gains in most cases if you increase it.
You have to use --crf 0 or --qp 0 for lossless mode
Not sure that makes any sense, unless you were using multipass encoding for the "final" version, or you are encoding multiple distribution versionsThe reason I want to encode to uncompressed/lossless is that my scripts are very slow so I'll encode to uncompressed/lossless 1 time. Then I can encode that uncompressed/lossless video to a watchable x264 video without a script at a really fast speed since I'm not using a slow script that time.
If your single "final" version was using 1pass CRF, you're just adding the extra time of encoding a lossless version on top so it will actually be slower overall
Probably it would make more sense to try optimize the script, or use avisynth+ x64 MT if you are not already
Both ffms2, lsmash support x264, ffv1What indexers support uncompressed/lossless videos? -
Ah I didn't see your edit... You're going to keep and store the lossless intermediate
But on the other hand, what if some super duper filters and workflow come around ? Making your filtered version obsolete or a lot worse relatively speaking ?
. So many people would keep the original
Not sure, I don't really use megui for many years . But I would think x264 qp 0 should workNeed something that will work with MeGUI One-click for batch processing. -
Will 10bit x264 lossless give a lower file size than 8bit? Non-lossless usually gives around 20% lower file size than 8bit.
I don't usually encode to x265 as I've been told that it doesn't yet retain small details as well as x264 does. But what if I encode to x265 lossless? -
Nope. In most cases , 8bit x264 will actually yield lower filesizes than both 10bit x264, or x265 8/10/12 bit for the lossless case specifically.
The only things you can tweak are GOP size, and presets can make a small difference . Usually not worth it using slower presets. It might take 5-10x slower to encode for 1-2% compression gain
x265 is a lot better than it used to be - it can retain small details now with the right settings. Overall it probably is better than x264 now in the majority of scenarios from a pure quality/compression viewpoint.
But for lossless encoding, long gop x264 8bit and FFV1 are the best for 8bit 4:2:0 content in terms of compression
720p video recording at same bitrate as 1080p video.
By ShadowWizard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 18th Jun 2017, 20:35 -
Reencoding video to a lower bitrate: downsample first?
By pachura in forum Video ConversionReplies: 3Last Post: 31st Mar 2017, 12:14 -
"Lossless" Video Encoding in AVISynth?
By U2Joshua in forum Newbie / General discussionsReplies: 5Last Post: 12th Dec 2016, 19:11 -
New lossless video codec
By JanKafka in forum ProgrammingReplies: 13Last Post: 23rd Jun 2015, 16:16 -
How to increase the bitrate of a video by avisynth ?
By avengerevenge in forum EditingReplies: 31Last Post: 11th May 2013, 00:13
