Hello Sirs. Its been a long while.
I've forgotten more then I think I knew so I need a bit of help with all these modern wizzbang tools.
I have a DVD structure copied to my drive and here is what I'd like to do.
I'd like to remove a single scene or span of time of the contents and wrap it in a MKV wrapper so that I lose as little as possible. To be clear I'd like to avoid reencoding even if the file size is a big larger then needed. (Source is already pretty dodgy) .
Any Advice for tools? As I said the DVD itself is already on my SSD.
Thank you sir. That should do fine I think.
Any suggestions for putting into an MKV container? -
MKVToolNix should be able to do the job.
After installing, open the MKVToolNix GUI, add your MPG, give it a name and a destination if you like, and "Start Multiplexing".
How to calculate for scene detection
By vhelp in forum ProgrammingReplies: 2Last Post: 8th Nov 2016, 02:23 -
Avisynth, help with scene by scene cropping
By KarMa in forum Video ConversionReplies: 4Last Post: 26th Nov 2015, 09:00 -
Scene-change flicker
By akkers in forum Video ConversionReplies: 8Last Post: 28th Oct 2014, 18:16 -
Recoloring the last scene in Taxi Driver
By Radio Radio in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2013, 18:43 -
can scene order in vobs be edited
By theewizard in forum EditingReplies: 2Last Post: 19th Apr 2013, 13:27
