  1. What can I do to improve the picture of this video?
  2. there is the multiple captures techniques for that, see here
    Otherwise i tried various filters, but it don't work that great, i know it work better with interlaced fields, so upload the original file, maybe there is a chance
  3. Thanks for the link. Here is a few seconds of the original file.
  4. like i said for the streaks the multi captures technique is your best option
    To clean chroma artefacts and some dropouts lines use this:
    SetMemoryMax(1200)
    SetMTMode(2,4)
    AVISource("George short.avi")
    assumetff()
    # To clean chroma noise (desaturation), light:
    ConvertToRGB32(matrix="Rec601",interlaced=true)
    separatefields()
    LoadVirtualDubPlugin("C:\Program Files (x86)\virtualdubmod1.5\plugins\Camcorder_Color_Den oise_sse2.vdf", "CCD", 1)
    CCD(10,1)
    weave()
    converttoyv12(interlaced=true)
    SetMTMode(2,4)
    SeparateFields()
    e=SelectEven()
    o=selectOdd()
    bvo = o.MVAnalyse(isb = true, truemotion=true, delta = 1, idx = 1, overlap=4, dct=1)
    fvo = o.MVAnalyse(isb = false, truemotion=true, delta = 1, idx = 1, overlap=4, dct=1)
    fco = o.MVFlow(fvo, idx=1, thSCD1=500)
    bco = o.MVFlow(bvo, idx=1, thSCD1=500)
    interleave(fco, o, bco)
    finesharp # mettre au début pour sharper les vrais détails
    dfttest (sigma=16, sigma2=16, tbsize=3)
    DeGrainMedian(limitY=255,limitUV=255,mode=5, norow=true) ## >>> to clean some dropouts but introduce some artefacts even though the weakest mode is used
    #DeGrainMedian(limitY=255,limitUV=255,mode=1)
    od=selectevery(3,1)
    bve = e.MVAnalyse(isb = true, truemotion=true, delta = 1, idx = 2, overlap=4, dct=1)
    fve = e.MVAnalyse(isb = false, truemotion=true, delta = 1, idx = 2, overlap=4, dct=1)
    fce = e.MVFlow(fve, idx=1, thSCD1=500)
    bce = e.MVFlow(bve, idx=1, thSCD1=500)
    interleave(fce, e, bce)
    ed=selectevery(3,1)
    interleave(ed,od)
    Weave()
    # To clean grain
    mdegrain2i2(4,0)
    # To clean chroma noise fluctuations:
    ConvertToYV16(matrix="Rec601",interlaced=true)
    separatefields()
    U = UToY().ttempsmooth(maxr=1,lthresh=150, strength=1)
    V=VToY().ttempsmooth(maxr=1,lthresh=150, strength=1)
    YToUV(U,V,last)
    weave()
    converttoyv12(matrix="Rec601",interlaced=true)
    function MDegrain2i2(clip source, int "overlap", int "dct")
    overlap=default(overlap,0) # overlap value (0 to 4 for blksize=8)
    dct=default(dct,0) # use dct=1 for clip with light flicker
    fields=source.SeparateFields() # separate by fields
    super = fields.MSuper()
    backward_vec2 = super.MAnalyse(isb = true, delta = 2, overlap=overlap, dct=dct)
    forward_vec2 = super.MAnalyse(isb = false, delta = 2, overlap=overlap, dct=dct)
    backward_vec4 = super.MAnalyse(isb = true, delta = 4, overlap=overlap, dct=dct)
    forward_vec4 = super.MAnalyse(isb = false, delta = 4, overlap=overlap, dct=dct)
    fields.MDegrain2(super, backward_vec2,forward_vec2,backward_vec4,forward_v ec4,thSAD=400)
    Weave()
    Mar 2018
    Poland
    Hi Dgicube, is the solution working?
    I currently have a similar issue:
    and it appear only with a batch of my 8mm tapes
  6. In the George short.avi (original) file, the streaks that extend all the way across the frame only happen on odd fields. One solution would be to bob it; replace the bad field with a motion estimated version created from the two adjacent bobbed fields, and then re-interlace.
