I'm trying to follow this guide: https://www.howtogeek.com/238725/how-to-fix-the-green-tint-in-the-lord-of-the-rings-fe...ition-blu-ray/
However, every time I try to put the avs file in MeGUI, it tells me "There is no function named DirectShowSource".
I've been scouring the internet to find an answer to this, but nothing is really helping. Any advice would be greatly appreciated.
I suspect MeGUI doesn't include DirectShowSource() because it's unreliable. (If your system isn't set up with DirectShow filters to read the file in question it won't work. And even when it works it's not frame accurate.) Use a differenent source filter, like LWLibAVVideoSource() or ffVideoSource(). If you really insist on using DirectShowSource() download AviSynth and copy the DirectShowSource.dll file to MeGUI's tool/AviSynth_plugins folder.
I found MEGUI X265 HEVC in MEGUI.ORG !!!!
By Stears555 in forum Video ConversionReplies: 11Last Post: 2nd Apr 2016, 14:00 -
The problem with MeGUI
By VideoHelp4Ever in forum Blu-ray RippingReplies: 8Last Post: 30th Mar 2016, 12:54 -
Problem file out with MeGUI
By yaston in forum Video ConversionReplies: 2Last Post: 29th Jan 2016, 01:34 -
MeGui problem - 2 jobs instead 1
By Moonwalker in forum Video ConversionReplies: 6Last Post: 19th Jun 2015, 01:40 -
problem with megui
By posan in forum Video ConversionReplies: 1Last Post: 10th Apr 2014, 03:14
