Our website is made possible by displaying online advertisements to our visitors. Consider supporting us by disable your adblocker or try DVDFab DRM and remove iTunes movie & music protection! :)
  1. Meteoric fall Solitary's Avatar
    Feb 2017
    Australia
    Hi
    Last week I decided to clean up some of my home movies and author them on to a DVD so they can be played on any DVD player as well as any computer. First step, of course, is to edit the clips as needed and turn them into a suitable format for burning and authoring.
    My equipment is ancient: AMD Athlon CPU, 4gigabytes of RAM, MS XP SP3. Itís slow as molasses, but thatís not a worry to me. I can let this box chug along overnight or for days if necessary and do stuff on my Linux unit.
    So here is my very first effort. I took this clip, filmed with a Canon IXUS 220 HS, and named it Bluetongue_chucks_a_uey_original.MOV
    Format                      : MPEG-4
    Format profile              : QuickTime
    Codec ID                    : qt   2007.09 (qt  /CAEP)
    File size                   : 45.7 MiB
    Duration                    : 15 s 82 ms
    Overall bit rate            : 25.4 Mb/s
    CNTH                        : "
    Video
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : Baseline@L4.1
    Format settings, CABAC      : No
    Format settings, RefFrames  : 1 frame
    Format settings, GOP        : M=1, N=15
    Codec ID                    : avc1
    Codec ID/Info               : Advanced Video Coding
    Bit rate                    : 23.8 Mb/s
    Width                       : 1 280 pixels
    Height                      : 720 pixels
    Display aspect ratio        : 16:9
    Frame rate mode             : Constant
    Frame rate                  : 29.970 (30000/1001) FPS
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Bits/(Pixel*Frame)          : 0.863
    Stream size                 : 42.8 MiB (94%)
    Color range                 : Full
    Color primaries             : BT.709
    Transfer characteristics    : BT.709
    Matrix coefficients         : BT.601
    Audio
    Format                      : PCM
    Format settings, Endianness : Little
    Format settings, Sign       : Signed
    Codec ID                    : sowt
    Bit rate mode               : Constant
    Bit rate                    : 1 536 kb/s
    Channel(s)                  : 2 channels
    Channel positions           : Front: L R
    Sampling rate               : 48.0 kHz
    Bit depth                   : 16 bits
    Stream size                 : 2.76 MiB (6%)
    and snipped just under 4 seconds off the end using VirtualDub and saved it as Bluetongue_chucks_a_uey_snipped.avi.
    Format                      : AVI
    Format/Info                 : Audio Video Interleave
    File size                   : 36.3 MiB
    Duration                    : 12 s 12 ms
    Writing library             : VirtualDub build 35491/release
    Video
    Format                      : AVC
    Codec ID                    : AVC1
    Height                      : 720 pixels
    Color space                 : YUV
    Bit depth                   : 8 bits
    Bits/(Pixel*Frame)          : 0.862
    Stream size                 : 34.1 MiB (94%)
    Color range                 : Full
    Audio
    Format                      : PCM
    Codec ID                    : 1
    Bit depth                   : 16 bits
    Stream size                 : 2.20 MiB (6%)
    Alignment                   : Aligned on interleaves
    Interleave, duration        : 35  ms (1.04 video frame)
    Interleave, preload duratio : 500  ms
    Next, I put the clip through VideoDubís stabiliser filter and named it Bluetongue_chucks_a_uey_stabilised.avi
    Format                      : AVI
    File size                   : 951 MiB
    Overall bit rate            : 664 Mb/s
    Video
    Format                      : RGB
    Codec ID                    : 0x00000000
    Codec ID/Info               : Basic Windows bitmap format. 1, 4 and 8 bpp versions are palettised. 16, 24 and 32bpp contain raw RGB samples
    Bit rate                    : 663 Mb/s
    Height                      : 720 pixels
    Bit depth                   : 8 bits
    Bits/(Pixel*Frame)          : 24.000
    Stream size                 : 949 MiB (100%)
    Audio
    Format                      : PCM
    Codec ID                    : 1
    Bit depth                   : 16 bits
    Stream size                 : 2.20 MiB (0%)
    I am happy with what the filter did. Not so happy that the file size has blown out from 36.3 to 951 MiB.
    So, the question is: What do I need to do to reduce the file size without compromising quality and will play on any DVD player?
  2. Originally Posted by Solitary View Post
    Two steps are a waste of time.
    Video-DVD is specified as max 720x576 with ancient MPEG2 codec. You will have to compromise quality to some extent if you insist on authoring DVDs that work on "any DVD player" (actually, with PAL/NTSC differences and whatnot that can't be guaranteed).
    Try AVStoDVD to author the DVD. Since it uses AviSynth it may be easiest to use one of the stabilizing filters for AviSynth and skip the whole VirtualDub process.
  3. Most VirtualDub filters work only in RGB. So incoming video is decompressed and converted to RGB. If you save that without selecting a compression codec you will end up with uncompressed RGB in a very large AVI file. if you want a smaller file select a compression codec. Or frame serve to an encoder that supports frame serving -- that will allow VirtualDub to send the video directly to another program without saving to an intermediate file.
