Hi Guys,
I have an Anime DVD which I'm looking to convert to x264. I think I need to IVTC the footage. I've applied some of my limited knowledge to understand the original frame rate and frame types for this clip.
Using Bob Doubler in virtualdub (TFF) I have identified a pattern of 2:3 over a scene with slight panning (frames 745-924). Adding TFM and Tdecimate in an aviscript works well but on the above scene there is ghosting. How do I remove this?
I also notice ghosting on frame 42.
I have a feeling I'm working with a difficult source here. I need some help in understanding the source material and the action I need to take to fix this before converting.
It's film with pulldown but some sections were sped up or slowed down with field blending. It won't be easy to inverse telecine. You'll have to work in sections then join them. Depending on you needs, it would be easier to just smart bob it with QTGMC() and leave it at 59.94 fps.
transcode Variable Frame Rate (VFR) AVC video to Constant Frame rate (CFR)
By hydra3333 in forum Video ConversionReplies: 2Last Post: 4th Mar 2018, 06:01 -
How to Determine Original DVD Frame Rate & Frame Type
By lomaidala in forum Video ConversionReplies: 30Last Post: 3rd Jul 2017, 08:42 -
Blu-ray frame rate of 48 & 24?
By clashradio in forum EditingReplies: 11Last Post: 1st Apr 2017, 20:46 -
Xmedia Recode & Variable Frame Rate
By BazzaG in forum Video ConversionReplies: 8Last Post: 15th Aug 2015, 10:52 -
Telecine and irregular dupe mix - restore original frame rate ?
By LMotlow in forum RestorationReplies: 16Last Post: 14th Jul 2014, 21:09
