  1. Jutht u wait u thilly ... hi.heaux's Avatar
    Jan 2018
    I read somewhere that if you're burning a home-made/youtube video to play it on your DVD player the format must be MPEG-2 or your player probably won't take it. Is that correct?
    I have a Youtube video which I downloaded and saved with an .MP4 extension. It plays fine in both VLC and FAB 7, but ripped to DVD media it won't play on my old DVD player. I'm an old hand backing up my movies but Youtube is alien to me. Could you recommend freeware programs that are all-in-one — meaning, automatically perform all the software steps — sampling, streaming, synching, etc. — in the conversion process, for a novice like myself? Thanks.
  2. Is that correct?
    Yes. A subset of MPEG-2 actually.
    Install AVStoDVD and ImgBurn. Drop your MP4 file onto AVStoDVD and press "Start" to produce a DVD that starts playback of your video when inserted into a DVD player.
  3. Jutht u wait u thilly ... hi.heaux's Avatar
    Jan 2018
    Originally Posted by videobruger View Post
    Install AVStoDVD ~~
    I installed it, but its executable won't run because I get the same MSCOMCTL.OCX Error that dozens of other people have gotten. The author assures the error has been cleaned up in his latest iteration — Version 2.8.0.7 — but that is the version I'm running.
    The only thing that comes to mind is an option (at some point) during the install where I was prompted to install an ActiveX file, which I didn't because Microsoft's ActiveX tool is notoriously buggy! and I avoid it anywhere and everywhere if possible. I've submitted a trouble ticket so I guess we'll see what happens . . .
    Mar 2008
    Install AVStoDVD ~~
    Are you running the portable version? Try the installer supposed to take care of it
    That file is the Windows Visual Basic controls, which the program needs
  5. Jutht u wait u thilly ... hi.heaux's Avatar
    Jan 2018
    I'd never go portable on something this object oriented. No, this was using the Installer, most definitely not portable.
