I have several clips i am editing. Some of them are more pixelated than others. Is there any program/software that exists that can either remove part of or all of the pixelation?
Use AVISynth with Deblock_QED(). Increase the strength as needed.
http://avisynth.nl/index.php/Deblock_QED -
I don't think anyone has any idea what you mean by 'pixelated". Do you mean block noise (macroblocks) or pixel breakup? Macroblocks are usually a sign of over compression (low bitrate unsuitable for the type of video you're working with), for which filters like DeBlock_QED and the original DeBlock are recommended, along with filters like dfttest used with 16-bit settings. The stronger you make the settings, the more they'll soften your video.
- My sister Ann's brother -
Deblocking will replace rectangular blocks with smooth gradients and may remove some true detail. That may not be an improvement. It depends on the source and what you prefer.
I think its macroblocking. Is there anything i can do using a video editor that might help reduce it?
Some video decoders have optional deblocking filters when they decode. Xvid, for example. h.264, h.265, and most other new decoders have deblocking filters built in. Mpeg 2 and other older decoders don't have deblocking. With those you have to use external filters. The aforementioned deblock_qed() is an AviSynth filter -- AviSynth is a script driven filtering system. Maybe you should provide a short sample of your video that shows the problem (don't filter it or reencode it).
Help with reducing (either it's echo, or reverb from audio)
By Infomaniac95 in forum AudioReplies: 3Last Post: 16th Nov 2016, 11:41 -
Reducing file size for dvd
By midweb in forum Newbie / General discussionsReplies: 9Last Post: 8th Sep 2016, 20:49 -
MakeMKV reducing pixel size
By enonod in forum Video ConversionReplies: 4Last Post: 25th Oct 2015, 11:45 -
Reducing dimension size
By rdeffley in forum RestorationReplies: 5Last Post: 20th Dec 2014, 13:03 -
What about reducing necro posting?
By bat999 in forum FeedbackReplies: 16Last Post: 15th May 2014, 23:30
