[Attachment 45133 - Click to enlarge]
Anyone know how to remove these annoying information while playing MP4 from my Potplayer?
I thought it was the general OSD (Tab) of the Potplayer, however, it's not, and I could find any way to remove them, it block 1/4 of my video!![]()
I'm just guessing, so I might be wrong.
- it might be some metadata/info/tag inside your mp4 video file muxed by the camera used to record it - txt, xml, etc. And PotPlayer picks it up as subtitles. See if you can turn it off - right-click, Subtitles - untick Show/Hide Subtitles (Alt+H)
- it might be a file outside mp4. See if there's something with corresponding name in the folder. There might be only one such file, but carrying info/data for each video file. Plus the file/s may be hidden and you need to change it in your system to see them. Try to take the mp4 file out of the source folder and then play it.
- use MediaInfo to see what's inside your mp4 apart from video (and audio). If so, use BOX4 (make sure to set audio and video to copy - so you don't lose quality) or MKVToolNix GUI to remux/repack your video. Untick everything you don't need.
- if you edit videos make sure your editting software doesn't need those additional files before deleting them.
What camera was used to shoot the video? Give exact name. -
genius!!! annoying text disappeared after disabling subtitles!!!
thanks so much!!!
Pot player remove text crawl below image url from You Tube
By loninappleton in forum Software PlayingReplies: 4Last Post: 4th Apr 2017, 14:23 -
How to remove file information display from Potplayer?
By Mystery123 in forum Software PlayingReplies: 11Last Post: 30th Apr 2016, 10:22 -
Pot Player Blu-Ray Time-On-Screen in Full-Screen
By robertkjr3d in forum Software PlayingReplies: 2Last Post: 31st Oct 2014, 04:46 -
Pot Player - How to Make it Open in Full Screen Mode When Launched
By jseidel in forum Software PlayingReplies: 2Last Post: 25th Jan 2014, 17:33 -
Pot Player - How to change the colour of the On Screen Display ?
By Digmen1 in forum Software PlayingReplies: 4Last Post: 21st Dec 2013, 13:49
