I have an empty main menu into which I have added a pre-made motion menu (M2V) that I created in Adobe Premiere. There's a 20 second intro and then another 20 seconds or so of the main background with the text/menu options, which I want to loop after the intro has played.
After adding the video, I added a new cell in DVD Lab Pro and dragged the start point of Cell 2 at the point where I want the looping section to begin (Cell 1 being the intro). I also added a sub-picture (BMP) in order to add buttons for Cell 2, as I don't want any buttons on Cell 1. After adding the sub-picture, I created group hotspots to link to the various videos on the disc as this is the cell where I want the buttons to become available.
However, after rendering the DVD out to a temp folder, when I play back the DVD in PowerDVD, none of my buttons appear after the 20 second intro. Cell 2 loops as I need it to, but there are no buttons at all. Does anyone know why this might happen and how to fix it?
I remember a similar topic a while back - it can be linked to at the bottom of this page.
Essentially for motion menus you create the menu/links on a blank canvas first BEFORE you add the video. The help pages should guide you. -
I think I've always done it this way before (that is, adding the video then the sub-picture, hotspots, etc).
I'll remove the video and try doing the sub-picture stuff again first but I don't see what difference that would make in terms of compiling.
How do I create a motion menu in DVD Lab Pro 2
By Xanadu2 in forum Authoring (DVD)Replies: 4Last Post: 20th Dec 2017, 18:52 -
DVD LAB PRO 2.52 Motion Menu
By litost88 in forum Newbie / General discussionsReplies: 1Last Post: 4th May 2015, 04:51 -
DVD Lab Pro 2 - buttons cut question
By Xoanon in forum Authoring (DVD)Replies: 5Last Post: 1st Nov 2014, 13:28 -
Motion Tracking buttons in Premiere Pro CC. Where can I found them?
By Stears555 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2014, 18:00 -
Tutorial how to make animate menu in AE with motion buttons
By avid in forum Authoring (DVD)Replies: 3Last Post: 20th Feb 2014, 16:44
