Hi guys !
I'm trying to make a DVD which includes 10 titlesets (VTS 1, VTS 2, one movie in each VTS) but, the problem is that, when I get the 10 titlesets ready, the program won't let me
compile the dvd.. And I'm using DVDlab PRO 2.52.
If someone could help me with this, I would be grateful![]()
Results 1 to 16 of 16
Been a long time since I used this but....
1. I assume you set up the project for multiple titlesets. That has to be done before you load any assets.
2. Just how long would the running order/disk size for these 10 movies be ?. DVDLABPRO does not do any encoding as such so if the total running time/disk size is exceeded it will fail
3. I recall seeing a progress log. That should also be recorded somewhere. Will help if you can locate and upload that. -
Ok. But I would not have done it this way.
Much simpler to have a single titleset. You can still have separate videos and even a playlist. That is what I did many years ago when I used the prog. That had quite a few albeit small clips and I even created a juke-box selection menu
I would have thought that the prog, being practically pro, would follow the dvd spec and allow VTS up to the permitted no of 99 (even tho I have never seen an authored dvd with that number)
If it allows you to create a VTS beyond 7 or 8 which seems to be a somewhat random number........
The log could still be useful. -
[Attachment 45147 - Click to enlarge] the program is doing that and after that when I've clicked OK the program don't do anything... It says "Creating Menus". but it doesn't create these,
it freezes after that when I've clicked OK button -
It looks like it is what is says, it does not have enough room. The message is pretty straight forward.
More so.
If you have all that disk space why are you writing to a drive with < 10 gig free ?. And both the temp folder and the final output folder on the same volume. -
One other thing.
You might have 32 gb of ram but DVDLAB Pro is a 32 bit prog. It will only see 10% of that.
That progress log could still be useful
Is DVDLAB Pro updated
if compiling shows 'out of memory' remove a vts and try again. -
[DVDLAB PRO] Someone can help me solve the HI-LITE submenu?
By kirous in forum Newbie / General discussionsReplies: 1Last Post: 9th Jan 2017, 21:16 -
Anything similar to DVDLab Pro
By anfield7 in forum Authoring (DVD)Replies: 3Last Post: 27th Sep 2015, 06:02 -
[DVDLAB PRO] Help!, Problems in the TITLE and TOP MENU buttons.
By kirous in forum Newbie / General discussionsReplies: 17Last Post: 8th Aug 2015, 10:23 -
[DVDLAB PRO] Help, I need to change region DVD in DVD LAB Pro
By kirous in forum Newbie / General discussionsReplies: 25Last Post: 16th Jul 2015, 08:07 -
DVDLab Pro Button Position Issue :(
By Shohag_ifas in forum Authoring (DVD)Replies: 4Last Post: 26th Nov 2014, 08:42
