Consider supporting us by disable adblocker or buy Replay Video Capture or PlayON and record Netflix!
Results 1 to 14 of 14
  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi guys
    I got a series set I am wanting to rip.
    it is an SD standard DVD.
    Basically it is a full series box set of my favourite TV show containing all 6 series.
    I would like to make a direct copy of it.
    Ideally I would like the folder layout like this...
    Series 1 then inside Series 1 is VIDEO_TS
    Then inside VIDEO_TS is that WHOLE series 1... even if series 1 has 2 or 3 discs...
    How can I rip it so the whole of series 1 can all be inside one VIDEO_TS folder?
    I am most familiar with DVD decrypter unless anyone can suggest another way?
    Just need help with the process and what settings to use (if any)
    Thanks.
  2. Member DB83's Avatar
    Jul 2007
    I doubt if that is possible.
    Theoretically one could use low-level tool such as pgcedit or ifoedit to create a linking to such a large virtual dvd. Yet I doubt if any software could play it.
    You could also rip the dvds to mpeg2 and re-author from there. But, again, no software allows you do exceed 8.5 gigs
    The only thing I can even think of is to have an iso of each disk under the folder. Your player might be able to access those but is that what you really want ?
  3. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hey!
    Yes that would be ok having the ISO thing.
    Do you know of a good guide of ripping TV series?
    All I would like to do is just make direct copies onto my PC. Would DVD Decrypter allow me to rip DVD TV series?
    Its just I got a whole box set of 'One Foot In The Grave' would like to backup the whole thing onto the PC completely untouched (so not reencoded or anything) which software will allow me to do this or is it just a matter of copying the VIDEO_TS files from the actual DVDs onto the PC?
  4. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hey!
    So I suppose it doesn't really have to include all the discs in 1 VIDEO_TS folder...
    Even if I just did itl ike this:
    One Foot in The Grave - Series 1, then inside that folder have a folder called DISC 1 of 3 then in each DISC folder have the VIDEO_TS folder which would be fine... which I am guessing would take up around 4.3GB per folder. So even if I just rip thosel ike that its fine... I just need a guide on how to do it.
    Feb 2006
    Originally Posted by SE14man View Post
    Hi guys
    Thanks.
    are you wanting to copy the original dvds to blank discs ?? you can try dvdfab clone mode option.
    which would be the exact copy of the original disc.
  6. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi there
    thanks for the reply.
    Actually just to have them on an external drive would be ideal if possible?
  7. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi there
  8. The commercial product DVDRemake (Pro) is the only program that can do this easily. It's possible, as DB83 mentioned, using all freeware, but it's incredibly hard.
  9. Member SE14man's Avatar
    Jul 2005
    Queensland
    That looks really good actually thanks very much
  10. Member SE14man's Avatar
    Jul 2005
    Queensland
    What about just ripping a dvd box set normally? Without cramming many discs worth in one video ts folder.
    What would you usually use just to backup the series on a pc?
  11. Member DB83's Avatar
    Jul 2007
    Well the old dvddecrypter may still work.
    Or there's makemkv. Methinks the decrypter part of DVDFab is also free.
    But do check out the 'DVD Rippers' from the software section of the site
  12. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    It took me a long time to give in but.....I'm hooked on mkv files through my TV or Blu Ray player.
    MakeMKV is awesome. You occasionally have to re-download a newer version, but you can still customize
    your final output(remove extra audio, subs and crap).
  13. Member SE14man's Avatar
    Jul 2005
    Queensland
    Thanks guys will try all suggestions and see which one works best for me
  14. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    I endorse hech54 comments - I liked MakeMKV so much I actually bought it! So no more re-registering every few months or so. Do give it a go really excellent program.
    BeyonWiz T3 PVR ~ Popcorn C200 and A-500 ~ Samsung ES8000 65" LED TV ~ Windows 7 ~ Yamaha RX-A1030 ~ QnapTS851-4G
