I'm considering downloading TMPGEnc Authoring Works 6, and I'm confused about whether my CPU meets the minimum requirements.
As stated on the Pegasys website, the minimum requirement for the CPU is:
SSE3 instruction support Intel Core 2/Core i or newer; or AMD FX or newer.
My CPU is AMD A8-6600K APU with Radeon HDGraphics, 3.90 GHz
Is that sufficient to run Authoring Works 6?
If I download the trial and everything seems to work OK, is that good enough?
Yes it should work, but it's at the low end, as is my own AMD FX 4300
.srt to .subtitle ( from TMPGEnc authoring works 4 )
By shaktiIIIgta in forum User guidesReplies: 5Last Post: 30th May 2022, 08:51 -
TMPGEnc Authoring Works 5 Menu Help
By hurricane1951 in forum Authoring (Blu-ray)Replies: 3Last Post: 26th Feb 2022, 15:28 -
TMPGEnc Authoring Works 5 Problem
By Mart7 in forum Newbie / General discussionsReplies: 13Last Post: 15th Aug 2015, 13:45 -
Help with Tmpgenc authoring works 5
By littlebase22 in forum Authoring (Blu-ray)Replies: 15Last Post: 16th May 2015, 01:44 -
TMPGEnc Authoring Works menu
By multitech in forum Authoring (DVD)Replies: 1Last Post: 3rd Oct 2013, 14:41
