I was able to transfer the AVCHD folder from my Canon Vixia R600 camera to a FAT32 flash drive and play it on my PS3 flawlessly. However, when I burnt the AVCHD folder to a BD-R, the PS3 refuses to recognize the AVCHD format and instead loads it as a data disc (Resulting in unwatchable playback due to the PS3's filesystem loading too many files at once from the STREAM directory).
I used IMGBurn to build/burn the disc in 2 ways: (1) with the root as AVCHD and (2) with the AVCHD folder as a subdirectory. Neither way worked.
I recorded in 1080/60p mode, which I speculate may be the problem (I was surprised it played as AVCHD off the flash drive, since I didn't think 1080/60p was supported on the PS3). Is there any workaround for this or am I missing something?
Probably because it is a data disc
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Maybe I should have suggested try using IMGBurn to burn it as a Blu ray video disc, might work - https://www.dvd-guides.com/guides/blu-ray-copy/260-burn-blu-ray-avchd-using-imgburn
Pretty simple: AVCHD has 2 specs, v1 and v2.
1080p60 video is only supported in v2,
And
Ps3 does not support either of the 2 variations of v2 - 60p or 3D. Ps3 only supports v1.
Plus, a proper burning of avchd puts the avchd folder within the [private] folder within the root folder,. So you also had the structure wrong, and no player would/should recognize it that way.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 22:18 -
Can't read DVD data disc on XP
By AlanHK in forum ComputerReplies: 3Last Post: 4th Sep 2015, 23:05 -
transfering AVCHD video to dvd-rw disc
By postie1392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 28th Jun 2014, 08:33 -
How to burn AVCHD files to disc without menus?
By ThomKelly in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Feb 2014, 21:14 -
AVCHD Disc creator for Mac?
By Ry-Dawg in forum MacReplies: 2Last Post: 29th Oct 2013, 13:25
