Hi,
Using WinX DVD platinum and I would like to add subtitles that you can enable or disable while watching the video.
I found how to add them in the video but I could not find the option to add subtitles that you can disable.
Can WinX DVD do this type of subtitles inclusion or do I need to use another software?
Thanks anyone for your help
Results 1 to 1 of 1
Soft .txt subtitles to mkv?
By lukasz12054 in forum SubtitleReplies: 2Last Post: 6th Mar 2017, 19:11 -
problem "burning in" subtitles on download video that has soft subtitles
By kasfig in forum SubtitleReplies: 2Last Post: 1st Feb 2017, 17:47 -
How do I include the closed-captions in youtube-dl videos ? .. [solved]
By vhelp in forum Video Streaming DownloadingReplies: 2Last Post: 7th Sep 2015, 12:10 -
convert dvd to mp4 multilanguage subtitles - closed captions
By kasfig in forum DVD RippingReplies: 3Last Post: 4th Apr 2015, 16:47 -
Getting soft subtitles on my iPad and Nook
By Cooljoe815 in forum SubtitleReplies: 7Last Post: 25th May 2013, 18:29
