I worked out a way to prevent the backward motion resulting from duplicate interlaced frames, while keeping the full 59.94 fps when there are no duplicates:
After QTGMC, when an even frame is the same as the previous even frame it is replaced with the previous odd frame. So with a sequence like:Code:Mpeg2Source("Stutter.d2v", CPU2="ooooxx", Info=3) QTGMC(preset="fast") even = SelectEven() odd = SelectOdd() odd_delayed = odd.Loop(2,0,0) even = ConditionalFilter(even, odd_delayed, even, "ydifferencefromprevious()", "lessthan", "2.0") Interleave(even,odd)
You getCode:0, 1, 2, 3, 2, 3, 2, 3, 2, 3, 4, 5
This prevents the backward motion at those even frames. Of course, you're still stuck with all the duplicate frames.Code:0, 1, 2, 3, 3, 3, 3, 3, 3, 3, 4,5
Results 31 to 34 of 34
Oh, I forgot to mention: the script in the previous post can simplified, though it may be a little less less instructive:
Code:Mpeg2Source("Stutter.d2v", CPU2="ooooxx", Info=3) QTGMC(preset="fast") even = SelectEven() odd = SelectOdd() even = ConditionalFilter(even, odd, even, "ydifferencefromprevious()", "lessthan", "2.0") Interleave(even,odd)
One may need to adjust the "2.0" threshold value for some clips. I was originally stamping the output of QTGMC with frame numbers so I could verify which frames were being substituted. That required a higher threshold for the comparison -- to eliminate false negatives. -
I take that back, removed the distributor() line at the end and now I'm getting 3 FPS! Hah! Now to go to sleep
VHS restoration
By DaneClark in forum RestorationReplies: 7Last Post: 9th Jun 2017, 13:07 -
Interlacing issue and restoration on VHS capture.
By VSz in forum Capturing and VCRReplies: 53Last Post: 30th Nov 2016, 19:58 -
old VHS restoration
By pirej in forum RestorationReplies: 72Last Post: 30th Apr 2016, 07:26 -
Looking for basic, fairly simple VHS restoration tips
By diprotic in forum RestorationReplies: 9Last Post: 26th Feb 2015, 17:43 -
VHS Family Wedding tape restoration
By Tafflad in forum RestorationReplies: 228Last Post: 19th Feb 2014, 13:44
