I noticed that if the option “Use autochange fullscreen monitor mode” is checked, the display mode settings (refresh rate & definition) are not reset if you play the file on another screen.
Example :
Step 1 : I watch a 24 fps movie on my secondary screen (1080p), the display mode is “[ 24 ] @ 1920x1080 p”.
Step 2 : I close MPC-HC, open it again on my first screen (computer, 4K@60Hz), the settings are still “[ 24 ] @ 1920x1080 p”, which is not adapted to that screen.
If I uncheck the option “Use autochange fullscreen monitor mode” between steps 1 & 2, there would be no issue for screen 1 (as there’s only one refresh rate on my first screen), but the settings would be lost for the secondary screen.
I’d like to be able to watch the movie on any screen, applying the settings defined for each.
Does MPC-HC work that way by design, or should I suggest a feature request?
Hi
Thanks for the answer. Indeed, it works the way I want : the best display mode is used on each display.
Now the drawback : switching to a different display mode involves an audio lag, which MPC-HC can handle for each mode. So I'm now using the "Optimize" function of madVR to resync audio & video.
Potplayer fullscreen mode without resizing or scaling
By gregory003 in forum Software PlayingReplies: 2Last Post: 18th Mar 2018, 00:05 -
How to remove open playlist bar in fullscreen mode?
By mikica90 in forum Software PlayingReplies: 4Last Post: 9th Apr 2016, 09:17 -
Yamb display problems in One Click Converter mode for converting subs....
By Greg2041 in forum SubtitleReplies: 6Last Post: 11th Jun 2014, 11:30 -
Laptop to TV OK in 720 mode but garbled video in 1080i mode
By impmon2 in forum Media Center PC / MediaCentersReplies: 1Last Post: 3rd Feb 2014, 08:50 -
wlmm - video clips display do not display correctly?
By OleMan in forum EditingReplies: 7Last Post: 12th May 2013, 10:32
