    Aug 2005
    Europe
    Is a 2560x1080 monitor a worthwhile upgrade from a 1980x1080 monitor?
    For example:
    http://www.lg.com/us/monitors/lg-29UM68-P-ultrawide-monitor
  2. Depends on your needs and preferences. I find 1080 lines tall isn't enough. So I use a 32 inch 2560x1440 monitor now.
  3. jagabo, can you share the make and model number with us? I am looking for such a beast. Thank you.
  4. Oops, duplicate post.
  5. I got a 32" 2560x1440 HP Pavilion on sale for about US$280 last year.
    https://www.amazon.com/HP-Pavilion-32-inch-Wide-Viewing-Display/dp/B01FGCJBGK/
    Before that I was using a 27" 2560x1140 display but that was too small for the resolution. At normal viewing distances small text was too small to read comfortably. 32" is a better balance for that resolution.
  6. Great deal you got there. Thanks for the information and advice.
