  1. I have a G4 733 Mhz Powermac and I am just learning how to convert .mov so I can play them on my DVD player (its VCD compatable).
    I think I am finally getting success after lots of help and advice from messages posted on here (I'm doing my first VCD now actually).
    Just a quick question;
    I've split a film in two using Quicktime and have dropped the first one onto Toast. How long will each half take, it seems awfully slow ?
    Also, how do I put it on a blank CD when its finished encoding ?
    All help much appreciated !!!
  2. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    About 5 hours or so depending on the quality you choose. To burn it use Toast. It can burn VCDs very easily. I've tried Neromax before, but it refused all mpegs I gave it.
    Jun 2001
    Silver Spring, MD USA
    I've burned a couple VCDs using Toast's encoder, and if I recall correctly, the first step in making a VCD with Toast from a Quicktime file is that it re-encodes the .mov to be Toast-acceptible. Once the file is Toast-able, then it asks you for a blank CD to burn the video to VCD.
    Beware: Apparently Toast encodes the video (for NTSC) to 320x240, which is not the VCD's standard resolution of 352x240.
  4. No Longer Mod tgpo's Avatar
    Feb 2002
    The South Side
    Once you finish encoding the .mov file to a .mpeg then you can burn. I'm not at home now to check what screen size Toast uses, but I believe it is 352x240.
