Hi.
I'm using Subtitle Edit for teaching purposes and I'd like to add comments to the students' subtitles in order to point their mistakes. More specifically, I want to add a new subtitle that overlaps theirs and has a different formatting (position, color, size, etc) as to make it more visible.
Here's an example:
1
00:00:00,001 --> 00:00:01,001
Incorect subtitle
2
{\an8}<font color="#ff4949"><i>You misspelled 'incorrect'</i></font>
When I load these subtitles on any video player outside of SE, it works fine.
[Attachment 45089 - Click to enlarge]
However, SE refuses to show them in its embedded video player. I've tried changing it to VLC and MPC-HC but it didn't work. I've also reinstalled VLC. It only shows the first subtitle on the list.
[Attachment 45090 - Click to enlarge]
How can I make it work? Is there another way to show one subtitle with two different formattings?
Thanks in advance.
I would use "Advanced Substation Alpha" (ASS) format with a separate style for your comments. As player use "mpv" (there's a button to download mpv lib in the same tab you select the player).
How to export a video in Subtitle Edit
By charrua1 in forum Newbie / General discussionsReplies: 2Last Post: 17th May 2017, 16:54 -
Software for edit video, audio and subtitles?
By apalaciosd in forum EditingReplies: 6Last Post: 8th Jul 2015, 18:12 -
How to edit video files with subtitles by SolveigMM Video Splitter
By DmitryV in forum User guidesReplies: 0Last Post: 9th Jun 2015, 10:33 -
Subtitle Edit Convert SSA Subtitles To SRT Issues!
By kairukun in forum SubtitleReplies: 3Last Post: 14th Oct 2014, 03:58 -
How to sync 2 subtitles using subtitle edit
By rronald_25 in forum SubtitleReplies: 2Last Post: 25th May 2014, 07:25
