Hey all
I've captured 30 mins of footage from a camcorder. I captured it as an AVI encoded with Huffyuv and the file is about 14 GB in size.
All frames are key frames in this format (HuffYUV).
So I trim a bit here and there, but when I save it, it takes about 15 minutes to complete. Is this normal? I thought it should be near instantaneous?
I didn't re-arrange any clips, nor applied any filters, etc...
Settings: Video and Audio are set to "Direct Stream Copy"
Video: 720*576 @25 FPS (PAL).
Hardrive: Mechanical @ about 80% of capacity. Origin and destination of video on the same partition. Hardrive was recently formatted.
OS and specs: Windows 8.1 32bit on a 7th Generation i5 64bit HP laptop. I'm using Windows 32bit because the capture card driver (an old Avid liquid Pro BOB) only works on 32bit systems. Win 8 is installed on a separate internal hardrive with 4 partitions.
What's going on?
Thanks !
Last edited by Gotanno; 1st Apr 2018 at 12:23. Reason: Misplaced ". Also added additional info.
HD or SD capture ? Maybe issue with your storage ? Is this a mechanical HDD ? Are you reading / writing to the same drive ? Is it fragmented or near capacity? Defrag and/or run some diagnostics.
Just a FYI - there are lossless formats which have long GOP modes too . eg. FFV1, x264, x265 all can use temporal compression in their lossless modes -
How long does it take just to copy the original file in the explorer? I doubt 30 mins is a small file.
Do a file copy from and to the same drive, using your 14GB original copy (assuming you have enough free space), as andkar suggested. That is your benchmark. A "direct stream copy" edited version using all keyframes should take only slightly longer than that.
Scott -
Save edited AVIs in Avidemux without reencoding.
By ts1971 in forum Newbie / General discussionsReplies: 2Last Post: 25th Nov 2014, 16:35 -
How do I save edited subtitles in PGS format (.sup) ?
By c627627 in forum EditingReplies: 18Last Post: 16th Nov 2014, 00:36 -
Uncompressed avi won't save in virtualdub
By light-vessel in forum Video ConversionReplies: 3Last Post: 28th Jan 2014, 15:30 -
VirtualDub -> Save image sequence... Batching problem
By csin in forum EditingReplies: 5Last Post: 29th Oct 2013, 10:07 -
12 TB of unedited formats and edited end videos. Best way to SAVE.
By jollygoodme in forum EditingReplies: 3Last Post: 15th May 2013, 22:16
