Hi
I bought some DVDs of old TV recordings but the picture and audio skip at around 1:03 and then every 33-34 seconds. It's only for a second but makes it unwatchable really.
Can anyone please help?
I've uploaded one of the vobs to show you:-
https://mega.nz/#!QkVD3Bza!YhzjQHOOOZdQsDkJjjlUNPLF-JKLTWLW4BfRzyJETGU
and the IFO file:-
https://mega.nz/#!w91kzIxR!e3d7lmq8xcNZRgKB7be7AhSz042ndyb9Wyk0hFzVgCc
Many thanks!
Nothing can be done to fix it,that's just the way it was recorded/encoded.
I played the vob and I did not find it as bad as you described.
There is some stutter probably from dropped frames in the capture. If you have what you describe then as well as that you could have a poor burnt disk.
Suggest that you rip all the files to your HDD and re-burn with quality media. -
You can replace the missing frames with motion interpolated frames in AviSynth. But you will have to go through the video yourself to locate all the missing frames. Then use a function like InsertFramesMC() to insert new frames. Your script will end up looking something like:
Of course, with a jerk every 30 seconds you'll have 120 InsertFramesMC lnies every hour.Code:Mpeg2Source("VTS_02_1.d2v", CPU2="ooooxx", Info=3) QTGMC(preset="fast") InsertFramesMC(8284,2) InsertFramesMC(6608,2) InsertFramesMC(4908,2) InsertFramesMC(3184,2)Last edited by jagabo; 29th Mar 2018 at 21:29.
How the heck do I split an MKV file less than 13 seconds?
By yuppicide0138 in forum EditingReplies: 5Last Post: 14th Nov 2017, 04:23 -
Multiple .VOB file to one file?
By neworldman in forum Video ConversionReplies: 12Last Post: 4th Jan 2017, 03:00 -
VLC waits 3 seconds before playing video bec. of subtitles (file attached)
By smellycat3 in forum SubtitleReplies: 8Last Post: 30th Dec 2015, 06:29 -
Converting from a 'dvd shrink 3.2' VOB file to an mp4 file
By misstimtam in forum Video ConversionReplies: 6Last Post: 14th Jan 2014, 16:58 -
how to merge an audio in audio file for particular seconds
By vijay123 in forum AudioReplies: 3Last Post: 25th Jun 2013, 05:42
