Here is the video file I'm dealing with...
General
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42 (mp42)
File size : 2.85 GiB
Duration : 2 h 10 min
Overall bit rate : 3 131 kb/s
Codirector : codirector
Production studio : studio
ContentType : Unknown Type
Encoded date : UTC 2018-03-29 04:59:13
Tagged date : UTC 2018-03-29 04:59:13
Video
Format : AVC
Format profile : Main@L3
Format settings : CABAC / 1 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 1 frame
Muxing mode : Container profile=High@4.2
Codec ID : avc1
Bit rate : 2 996 kb/s
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.135
Stream size : 2.73 GiB (96%)
Language : English
Audio
Format : AAC
Format profile : LC
Codec ID : mp4a-40-2
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 SPF)
Compression mode : Lossy
Stream size : 119 MiB (4%)
Title : Stereo
Language : English
Default : Yes
Alternate group : 1
All I'm trying to do is create a file that will burn to a DVD+R AND be playable on an up to date 1st genration PS4. I would consider myself a novice, but I'm trying to learn. If someone would be kind enough to help me, you may have to walk me by the hand through the steps, and I apologize for that. I have a lot of video editing software, but the burning software I mostly use is Ashampoo 16, only one I really, kinda, sorta know how to use...lol...I've Googled the hell out of this and got nowhere. I really don't know what else to do.
Some of the video software I have, but a noob at using all of them...
tsMuxerGUI
imgBurn
BD Rebuilder
MKVToolNix GUI
MKV2AC3
MeGUI
Any Video Converter
ImTOO Video Converter Ultimate
Wondershare Video Converter
Maybe I just don't have the software to get the job done or the smarts...lol
: 1
Results 1 to 15 of 15
Quick question...
Why are you using a big font?
And mine's bigger.Want my help? Ask here! (not via PM!)
I apologize, I'm legally blind. Sometimes I have problems seeing small text. I wasn't trying to annoy anyone, I'll go smaller, if need be. Sorry.
For an easy way to accomplish the task, try AVStoDVD - available from the software section on Video Help. Since you already have ImgBurn installed, which it uses to burn the final product, it should not ask you install that, but decline if it does ask. AVStoDVD is pretty easy to understand but there are guides to help with the task.
Since you are doing a DVD, it does make a compliant DVD that should work on the PS4, but I cannot answer to that, as I do not/have not used a PS4.
Come back if you have more questions. -
Are you sure that your file can't be played on PS4 without conversion? this type of files was played on PS3 without any issues (container, audio+video codecs supported on PS3) - perhaps you can just copy file to your video folder without conversion (seem PS4 is unable to play files directly from USB). Accordingly to PS4 Media player supported file types everything is OK
Yes, this was no issue on the PS3, but the PS4, it seems to be an issue. I looked up the PS4 Media Player & it shouldn't be a problem. I have tried burning the file just the way it is & it says disc is unsupported, doesn't give a reason why. Crazy.
Not sure how to do that on the PS4. I used to be able to copy/save files to the PS3. But that actually wouldn't help me, I enjoy having physical copies.
Psychoboys, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz -
I got it! I got it! I used ConvertXtoDVD. Its simple to use (had to be for me to figure it out). And as a bonus, Ieven figured out how to make a menu using custom background image & audio! Thank you guys for all your help, much appreciated!
Now that you guys have helped me with that issue, I have another for you...lol...Using ConvertXtoDVD, I can't seem to figure out how to save the output file to my HDD. It just burns it to a disc. Burning it is fine, but I'd also like a copy on my HDD, created menus and all. Any ripping program suggestions?
I haven't used ConvertXtoDVD in a while,
but under the 'General' tab, there should be a 'working folder' location.
That should hold your completed DVD files. If you copy those,
you should be able to edit or do what you want with them.
They are automatically deleted when you burn unless you de-select that option.
You may be able to cancel the burn also, but set the tab so it doesn't delete them first.
Please help- RAW .264 file needs to be playable
By eagle132 in forum Video ConversionReplies: 12Last Post: 28th Feb 2017, 01:11 -
minimum re-encoding mini dv movies to create blu-ray playable on player
By Jean88 in forum Video ConversionReplies: 9Last Post: 25th Sep 2016, 20:13 -
from VOB to SmartTV playable file, With Subtitles
By Raul Costa da Silva Perei in forum Video ConversionReplies: 2Last Post: 1st May 2014, 21:10 -
PS4 Vs Barrett 50 cal
By Noahtuck in forum Off topicReplies: 1Last Post: 15th Nov 2013, 11:04 -
Create and burn dvd's and cd's.
By pmjokes in forum Authoring (DVD)Replies: 15Last Post: 27th Oct 2013, 17:26
