    Mar 2018
    Michiana
    I am trying to find a product that will convert .mkv to .m2ts and PRESERVE the 8-channel audio. Plenty of products will convert the video, but not give 8-channel audio.
    Aug 2010
    San Francisco, California
    If you are not command line-averse, FFmpeg will do this easily using -codec copy.
    Mar 2018
    Michiana
    I used this command on the file I have attached: C:\>ffmpeg -i Dolby_Spheres_v1_Lossless-thedigitaltheater.mkv -codec copy shperes.m2ts
    While the conversion was happening, I received tens of thousands of the error "Non-monotonous DTS in output stream 0:1;...". I have attached a screen shot of those.
    What have I done wrong?
  4. Originally Posted by Spica66 View Post
    Nothing - this is pretty common warning provided by ffmpeg when some non ffmpeg created files are processed - if result works for you then you can ignore those warning messages .
    Aug 2010
    And if you don't want to see the warnings, add -v error to the command line.
