Hi! I have a LG UH12NS30 in a PC running Win7. I wanted to use DiscSpeed to test some BD-Rs. It correctly identifies them as CMCMAGBA5 under Disc Info. But all test options (xfer rate, create data disc, etc.) are grayed out. I had also tried Speed 4.11 with same result. At least I could create and check a DVD-R.
Is there something needed to unlock the BD-R capability?
Thank you!
Are you sure that your drive supports these tests? As far as I know LG drives generally don't and personally I never came across with one that does.
Thank you for your reply! Mystery solved, it was my fault, I didn't realize this model can't record BD. The specs say "DVD±RW (±R DL) / DVD-RAM / BD-ROM drive".
Kind regards
Daniel
Test for you
By Baldrick in forum TestReplies: 93Last Post: 6th Oct 2026, 08:39 -
Where to Find Test/Sample MP4 Video Loop to Test Webcam?
By pone44 in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2017, 18:50 -
Nero DiscSpeed & Info tool can't see 3rd drive
By videobruce in forum Newbie / General discussionsReplies: 9Last Post: 17th May 2014, 07:38 -
Let's Test!
By Endoro in forum TestReplies: 9Last Post: 21st Dec 2013, 07:46 -
test
By Ogilvy in forum TestReplies: 5Last Post: 29th Nov 2013, 22:31
