I just bought a pci express usb 3 controller based on VLI VL805 chipset and it came with drivers for Windows 7. Even though I don't plan to "upgrade" soon, I am wondering if the controller will work under Windows 10, as I can't find any drivers to download?
in principle Windows 10 has drivers for usb 3.0 built in but i'm not sure this is true for Via
The only driver there is for via based cards are find here: http://www.via-labs.com/driver.php -
I downloaded the latest Windows 7 drivers from the above link and it's a good thing that these were recently (2018-03-02) updated. However, there is no mention about Windows 10.
Check vendor site - VIA driver may not work with your card due possible firmware differences. Seem vendors providing working Windows 10 drivers for this chip.
I checked a few vendors and I did not find any Windows 10 drivers for their VLI VL80x based products.
According to this page
https://www.via-labs.com/product_show.php?id=48
It says support is offered in Windows 8 and 10 by the "inbox driver" -
Seem Gigabyte provide such driver https://www.gigabyte.com/Motherboard/GA-990FXA-UD3-rev-40#support-dl
However StationDrivers reports that they are up to Windows 8.1 (you need to test if 8.1 working on 10 by yourself).
Perhaps VIA didn't pay for certification then you can consider your HW as abandoned (quite common nowadays) also VIA is not most reputable brand and overall driver quality may be lower (seem software from all China/Taiwan vendors is low quality) - perhaps i'm very old guy but i learn that best USB IC with best (lower number of problems) drivers are from NEC (now Renesas).
Not sure about Windows 10 but i had impression that any XHCI compliant HW should work with generic driver provided with system.Last edited by pandy; 27th Mar 2018 at 16:26.
Sata controller on main board?
By bevills1 in forum ComputerReplies: 27Last Post: 27th Mar 2018, 13:54 -
can't install Asmedia usb 3.0 driver/USB 3.0 Host Controller not found
By clashradio in forum ComputerReplies: 18Last Post: 28th Sep 2017, 09:05 -
Firmware-update instructions- secondary IDE controller ?
By 3dreal in forum Newbie / General discussionsReplies: 9Last Post: 31st Dec 2016, 00:46 -
Bad Drive or failing controller ?
By DB83 in forum ComputerReplies: 28Last Post: 24th Oct 2016, 09:17 -
Problems With A Bluetooth Wireless Controller (PS3)
By Arthur_Ballsack in forum Off topicReplies: 1Last Post: 8th Aug 2014, 19:25
