Hi
I need some help.
When i convert a divx to vcd, the mpeg movie not work in my dvd stand alone player but on my computer.
I remark that at the bottom of the Tmpgenc window, the settings is : Mpeg 1, 352x240, 44100 Htz.......but not Video CD Mpeg 1.......
Someone can help me????
Hey Bud I'm not going to be able to answere your question but I have one for you. Is there a web site with directions on how to convert divix to avi or mpeg. I have a few divix movies and I would like to convert them and not have to buy them on dvd. Thanx alot Jake_
I'm not to up to speed on eveything but is your stand alone dvd player capable of playing vcd's?
Your problem might be that you are not using a VCD template for TMPEnc. Load one, they should be included with your program.
Also make sure you are using the right format (NTSC/PAL) and if you're using NTSC make sure the frame rate is appropriate (24 or 30 depending on the source framerate).
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE> -
Jake, try at : divx-digest.com
And yes, my stand alone dvd player can read VCDs!!!
Greedo, have you got an example for the TMPEnc Template, which one is the best???? Concerning the frame rate, i'm using the right format (i think so) 29.97 for NTSC but it doesn't work......
Thanx a lot guys
Convert A DivX with AC3 To VCD
By Stinky in forum User guidesReplies: 43Last Post: 23rd Jul 2011, 03:55 -
VCD to Divx conversion
By silverarrow in forum MacReplies: 14Last Post: 18th Feb 2010, 08:25 -
Divx to VCD
By d_unbeliever in forum Authoring (VCD/SVCD)Replies: 16Last Post: 30th Apr 2009, 00:19 -
VCD to DIVX Conversion
By DarkPhoenix77 in forum MacReplies: 2Last Post: 16th Mar 2009, 12:28 -
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01
