1)
There are some movies I've downloaded where Media Player Classic is not "easy" skipping to a certain point.
If these were old avi file I would have thought of a broken index but they are all MP4 or MKV, I've tried to repair with Meteorite the MKV but same issue.
The funny thing is: If I convert them with e.g. Handbrake even the destination file experiences the same problem.
2)
A slightly different issue I'm experiencing is where a source file is large in size but good quality; so when I convert it into a smaller .MKV the result is a terrible video quality file with blocks of pixels appearing randomly.
This happens with certain files only and not very often, I'm wondering if there's anything I could try to do differently
1) Just like AVI, also MP4 and MKV have keyframe index chunks, which may be missing or corrupted if you download movies (either transfer issues, or originally created by stupid people). The recommended original multiplexing software for such containers (e.g. MP4Box and MKVToolnix) may repair missing indexes, or at least display sensible messages if it can't.
2) MKV is a container format. If you reduce the size during conversion, then you converted the video stream into a new video format, and that way you will certainly loose some amount of quality, especially when you use even less bitrate than your original. On top, if you had some data corruption in your downloaded video, a converter will expose them as video corrpution, even though you may not see it just as obviously in a media player.
Trouble converting from Mini DV to iMac iMovie (loss issues at times)
By TKHanson in forum Video ConversionReplies: 1Last Post: 18th Dec 2016, 12:47 -
Converting VHS tapes to Digital - VFR Audio Sync Issues
By Foolio64 in forum Video ConversionReplies: 2Last Post: 9th Jan 2016, 13:59 -
Having issues batch converting raw .264 cctv files with FFMPEG-
By raidecker22 in forum Video ConversionReplies: 11Last Post: 22nd Aug 2015, 15:58 -
Pixilation Issues After Converting From MKV To Avi. Need A Solution
By stoksyXL in forum Video ConversionReplies: 24Last Post: 14th Jul 2014, 07:35 -
Quality Issues When Converting Captured VHS Footage, Need Help!
By kjw873 in forum Newbie / General discussionsReplies: 8Last Post: 15th Jan 2014, 21:32
